tgrayson
True. But if you are acting PIC, you can ALWAYS log it as PIC.
Please show me a regulation that says this.
I pointed out the Examiner not "logging" it... to simply illustrate that in your scenario... you would have no documentation of a PIC for that flight... and that doesn't make sense.Remember, logging and acting are two different things.
I have pointed you directly to a FAR that effectively summarizes my view as well as the view of the FAA on this matter. If you would be so kind... could you please point me in the direction of a Federal Regulation that states what you are claiming in this sentance?There are other well-known situations in which no one can log PIC time, such as when a private pilot allows a non-pilot friend to fly the airplane.
FAA's Defintion of Pilot In Command:Please show me a regulation that says this.
In the checkride scenario... a Student Pilot Certificate is the appropriate rating. Just as it is the appropriate rating to log PIC during a solo flight as a student pilot.FAA said:FAR Part 1 defines the pilot-in-command as follows: "Pilot-in-command means the person who:
- Has the final authority and responsibility for the operation and safety of the flight;
- Has been designated as pilot-in-command before or during the flight; and
- Holds the appropriate category, class, and type rating, if appropriate, for the conduct of the flight.
Thanks
But you aren't arguing about logging, you are arguing that there are cases where no one is PIC.
Student pilots can log PIC when alone in the airplane.
I also do not see a provision in 61.51 for logging PIC during a checkride for student pilots.
If the student isn't acting PIC on the checkride, who is?
If the student IS the acting PIC, can't they log PIC?
Break it down and read 61.51(e) a bit more carefully...Again, not relevant. Logging of PIC time is contained in 61.51(e). Logging of PIC time is different from acting as PIC.
(4) A student pilot may log pilot-in-command time only when the student pilot--
(i) Is the sole occupant of the aircraft or is performing the duties of pilot of command of an airship requiring more than one pilot flight crewmember;
Yeah... 'cuz Examiner's give checkrides all the time to themselves...the checkride does not require more than one crewmember.
FAA.gov said:In summary, the person who is pilot-in-command may log PIC, others may also log PIC depending in the circumstances.
Yeah... 'cuz Examiner's give checkrides all the time to themselves...![]()
Don't be...Well I'm still confused.
Alright then... I'll go with 'you're right' on this one... the examiner is not a required crewmember. However, when the examiner specifically states at the onset of a checkride that they are not the PIC and will not be acting in any way as such... then.... who does that leave as the "required crewmember"?Still not a requied crewmember by definition.
Logging Pilot-in-Command Time Read all of it... but most importantly... the last sentence.
