Hey all, Im currently working on my ASEL. However I am having some difficulties with some of the maneuvers. Specifically with lazy 8s and chandelles. So CFI's and students Im asking you to help. Share some techniques you have used to master these maneuvers. I have been practicing and practicing and just cant get em down. My instructor and I are getting real frustrated. Please help.
:banghead:
What type of aircraft are you flying?
I am in the process of finishing up two Commercial pilots that I have been working with the past week. One finished his CSEL ride Friday (Pass) and the other takes his checkride Sunday. Here is my advice:
1) Take your time setting up the maneuvers. Any variation in entry speed, power, or attitude is going to change the desired outcome.
2) Take your time when doing the maneuvers. Too many students rush them. Chandelles and Lazy Eights are slow, methodical maneuvers. I have had a lot of students do wing-overs instead of Lazy Eights. Slow the plane down and do it right. You will be rewarded with the desired outcome within PTS.
3) On Chandelles, count: "One one thousand, two one thousand" at the ninety degree point before starting the rollout. Most students either A) Identify the 90 degree point before actually arriving at it or B) Take out too much bank initially. This will take care of both problems. Just don't count out loud on your checkride!
4) On Lazy Eights, just set an initial bank of 10 degrees. What will happen as you pitch up is that the aircraft will continue to bank anyways, and you will get you the 45 degree point and have an easy transition to 30 degrees of bank. Make sure you don't rollout too much bank for the 135 degree point.
The maneuvers are relatively easy once you get them! I actually think steep spirals and 180 degree accuracy landings are more difficult to learn and perform consistently since varying conditions greatly affect the outcome.
My student on Friday had to do this on his checkride:
1) Steep Spiral over an Airport
2) Combined with a simulated emergency landing
3) And the 180 Degree Accuracy landing thrown on top of that!!!!!
-Michael
