This should be another reason for those fence sitters to finally make the jump. But but but...........we don't need a union. Life is good here. Just as the company sits across the table from you and leaves you high and dry for the FAA. Have fun explaining certificate action when your at your interview at the majors!!!
Over the past several months there has been a dramatic increase in the number of pilot deviations involving SkyWest Aircraft in the national airspace system. As a result of this, ATC and the Chief Pilots’ will be enforcing a zero tolerance policy for ATC deviations.
ATC doesn’t like to take action against pilots if it can be helped, but the amount of deviations needs to be curbed and from now on ATC will be taking action in all pilot deviations regardless of whether a loss of separation occurred or not.
ATC managers call us anytime there is a pilot deviation of any kind. If a deviation is reported to us by ATC you will be called in to the Chief Pilots office for counseling.
We realize that the vast majority of you operate in a safe, conscientious and vigilant manner and appreciate your attention to detail. Please help your passengers, SkyWest, and ATC out by continuing to foster this mentality in your peers.
Use good radio procedures, CRM, follow SOP and most of all stay sharp and professional! The gun sights are on us and we don’t want to see anyone of you involved in certificate action.
Call anytime with questions.
To all crews:
ATC is WATCHING you!!!!
