Runway 10/28
Dimensions: 6501 x 150 ft.
Runway 18/36
Dimensions: 5379 x 150 ft. / 1640 x 46 m
How much room do you guys usually eat up. On a good day, clean rw.
Runway 10/28
Runway 18/36
I know several companies have told their crews to just use brakes unless they need the TRs. Fortunately when our company tried to do that the (company) safety department stood up and said it wasn't going to happen it they weren't going to make a suggestion as to how crews stop the airplane.
Anything less then 5000 is technically a CA only landing for us. We used to do Key West and I think that was 4100 and the problem was getting out, not getting in.
The deal here is in the touchdown zone, nosewheel down ASAP, brakes and TRs ASAP on a slippery runway. On a dry runway, I'll aerobrake as well, but not on a slippery one. Wonder if there was a tailwind to factor in, too.
It drives me nuts to ride in the back and watch guys roll to the end of a 9000-10,000 foot (DRY) runway (and farther away from the terminal I might add).Unfactored landing distance at max landing weight (47k) is normally right around 3000 feet. However, it all depends on where you put it down and the runway conditions.
Well, if you're on time, less brake use DOES convert to lower MX costs. Lots easier on the airplane to just let it roll.
NTSB said:
Brakes are included to be used, as are thrust reversers. I'm not advocating max braking every time, but 10000 feet?!?!?!, that's ridiculous for an RJ, and most mainliners. Passengers want off the plane, not a tour of the airport. Especially like my recent Eagle RJ flight where it was 90 degrees in the cabin and the unfriendly/rude flight attendant would not inform the crew for the last :40 minutes. I guess they were conserving the A/C pac, eh?...less brake use DOES convert to lower MX costs. Lots easier on the airplane to just let it roll.
