They taught us the phrases terminal and non-terminal at Riddle. Could this be a "pilot factory" phrase to make it easier to remember when to time 2 versus 3 minutes on the outbound leg to a procedure turn? Could it be that instead of saying "with a VOR located on the field, you fly outbound for 3 minutes" they say "terminal approach is a 3 minute outbound leg"?
Yep, that's about it.
I do use the terms 'terminal' and 'non-terminal', ...wait, I just use the word 'terminal' to indicate it is on the field. I don't think I use the 'non-terminal' word, but it is implied, I guess.
I've always used the word terminal, guess it came from the concept that the VOR is the MAP, and that is the big difference to look at.
The rote 2 or 3 minutes outbound is a 'pilot mill' technique that gets schooled into the idea that it is a 'standard'.
Those are rough approximations of time, but time is unique to the approach.
Depends on how much altitude you have to lose, if any, during the PT, as well as wind.
A PT on 'non-terminal vor approach with no altitude would be about 2 minutes. If you have altitude to lose....go longer.
A PT on a terminal approach is a different matter and takes more planning. Again, it depends on how much altitude you have to lose after the turn and established inbound. Three minutes, evenin in wind, is not usually enough. You want to plan on being down to MDA at least one minute before you arrive at the MAP, so 3 out would only give 2 in which is only enough to lose a little under a thousand feet comfortably, and if you have any tailwind, you won't get down even close.
The whole point of all this ramblin' is that a rote 2 or 3 minutes is...
???...what are you thinkin'...???
