Story on Mitsu MU2 on CNBC tonight..
av8sean
10PM Eastern time (Wednesday)... Basically making a big deal about how often they crash etc.. should be worth a watch.
Its not showing up on my program guide, are you sure its on CNBC? I would like to watch it since I fly one regularly with a friend....
It seems David Farber is doing the report. Found this email exchange from over a year ago:
Begin forwarded message:
Date: May 12, 2005 2:30:24 PM EDT
To: dave@farber.net
Subject: Re: [IP] more on One DC-area pilot on air vs. ground vulnerabilities
Reply-To: Mary Shaw <mary.shaw@gmail.com>
Does everyone understand what a Cessna 150 is? It weighs 1100 pounds empty (that's pounds, not tons), its maximum gross weight is 1600 pounds.
That gives it a load-carrying capacity of 500 pounds. That's total people and all the stuff, including the gas to fly the airplane! The fuel tank holds 22.5 gallons, for 135 pounds, and it holds 6.5 quarts of oil for another 12 pounds. A standard person is 170lb, so with a pilot, full gas tank and enough oil that the engine won't sieze up before you get to your target you can carry less than 200 pounds of anything else menacing.
I've flown these things. You can fly them over gross weight, but not by much if you actually want to get off the ground.
Compare this to a Chevy Suburban, with an 8600 lb GVWR, 2800 lb payload, and a 37-gallon fuel capacity.
The Suburban is almost 6 times as heavy at max weight, has almost 6 times the payload, and could carry almost two fully-loaded Cessna 150s if you could fit them inside.
That Cessna 150 should be off in its hanger snickering quitely about scaring an entire city.
Mary
Date: May 11, 2005 11:40:09 PM EDT
To: politech@politechbot.com
Subject: [Politech] One DC-area pilot on air vs. ground vulnerabilities
[Identifying info snipped. Received this too late for the earlier
roundup. --Declan]
I like the way you think! I think it is widely accepted, but not widely
understood, that freedom was the real target of the 9/11 conspirators.
Unfortunately, it is STILL under attack...from within... which is also
exactly what was hoped.
If you missed this from a few weeks ago, here is the headline
published in
the UK regarding the most recent FRZ incident prior to today.
Incoming cloud forces Bush into safe bunker
I still have hope that there are those who will look at this incident
today
as evidence that the currect security construct is flawed and that
expanding
its reach through the air IS the wrong response. The security apparatus
continues to react to under the guise of perceived terrorism with
consideration for only select consequences.
In my view, until every building in DC with a parking garage has a "SUV
Restricted Zone" (an SRZ), or only commercial buses with pre-boarding
security screening services and codeword access can drive people in
and out
of DC, I question the security restrictions currently imposed on
access to
the NATIONAL Airspace System within ~30 miles of DCA. (BTW, I don't want
surface movement restrictions to happen either - I also oppose the
closing
of PA Ave.)
Instead, there is a foolish mis-perception generally that weapons
delivered
by air are of the highest and only serious threat. All other threats
are
assumed to be nearly zero. It is unfathomable to me that the current
threat
mitigations are assumed and perceived to be adequate. Moreover, these
perceptions and assumptions are being perpetuated by the "Security
Apparatzi" instead of systematically challenged - which satisfies my
definition of group think. The result is called a "false sense of
security."
Coincidentally, I saw NBC4 DC's report describing the US Capitol train
tunnel vulnerability. If anyone needs a map, you can download it
from the
news site. Here is an excerpt from
http://www.nbc4.com/news/4471435/detail.html :
"It's an important link. All southbound Amtrak trains go through the
tunnel,
as do commuter trains.
The tunnel passes under and near some of Washington's iconic Capitol
Hill
buildings, including the Supreme Court the Capitol itself. An explosion
below could shake the center of government."
Do I need to ask if anybody calculated the payload capacity of an entire
train lately?
While the consequences of another terrorist attack on DC are arguably
unquantifiable, I cannot see that the method of delivery will matter
or that
another attack will be total in its success. The current security
infrastructure for airborne threats comes at the equally unquantifiable
expense to liberty, and the considerable expenses of such general
disruption
and allocated security resources. These are the real consequences;
not the
specific well-being of any ONE person.
If someone walks down the street with a gun visible and holstered,
should
they be immediately arrested and questioned? Well, if you drive a
white van
or fly a plane near DC on some days, the answer is becoming... yes. The
proof for this argument just came over the wire:
Pilots Responsible For Capital Scare Won't Be Charged
This is exactly the evidence of "free society" hypocrisy that terrorists
cherish, and provides additional fuel for their recruitment efforts.
_______________________________________________
Politech mailing list
Archived at http://www.politechbot.com/
Moderated by Declan McCullagh ( http://www.mccullagh.org/)
You are subscribed as mary.shaw@gmail.com
To manage your subscription, go to
http://v2.listbox.com/member/?listname=ip
Archives at: http://www.interesting-people.org/archives/interesting- people/
WOW they really bashed the MU2 on that program.....Families ganging up trying to ground the airplane. Not getting any headway with it, bc the FAA is not planning on it but they did just implement having to go to a currency school....
Yeah, I like how the host states in the middle of the segment that the FAA reversed their course on the training required in 2005, but at the end of the segment he makes the claim that this new training was because of their "investigation". It just looked to me like a crock on the side of CNBC. I will agree though that something about training or type ratings for the MU-2 should have been dealt with long before now.
I loved the comment from a family member that said the Mu-2 crashes were the equivalent of 30 747 crashes... I don't want to downplay their loss, but come on...
I think they were talking about a percentage that would equal to.
A lot of those planes have gone down. If the same percentage of 747s bit the dust you better believe they wouldnt allow 747s to fly.
This is where the FAA drops the ball, same thing as allowing pilots to be on duty for ungodly hours and letting companies like Mesa take advantage of it. Cargo companies like the MU2 for its speed and they could care less about how dangerous it is as long as it is profitable for them.
You guys are reading more (or not enough) into this. First, they said that the FAA came out with a new rule "after" their report. They did not say it was a result of the report. These things are taped weeks in advance and they footnote the program when it is aired.
Second: The family members stated that it was a number of airframes lost (and that they were not comparing total passengers) which was alarming. And I totally agree. Do a quick NTSB search and you will find 41 fatal MU2s accidents in the USA since 1985 compared with 5 737 (airborne) fatals. Their point was, could you imagine the outrage if (30) 737s crashed in this time period? The FAA/public outcry would be HUGE!!!! But 41 MU2s have been lost since 1985 and the response is........crickets.
If you dig a bit further, you will notice that the accident to fatal ratio is extremely high for the MU2.
PS....Make a note, this is probably the ONLY time I have agreed with the media.
What reasons were given as to why the MU2 has so many accidents?
i believe they said the aircraft is difficult to control at low speeds, such as final approach and turning while at a slow airspeeds.
anybody know if this is true and has been confirmed as why these mishaps have happened?
what i did like though was when the host went up in the MU2 and asked the pilot a couple of times if he's surprised that "high time" pilots went down. he didnt ask again when the answer was- high time pilots make mistakes too.
The segment just re-aired and I was able to catch it. They did bash the MU-2 but at least the reporter actually went on a flight in one. I didn't realize that a hundred plus of the seven hundred some MU-2s made have been involved in crashes. The pilots who fly them are proud of them, and I think training is the answer to flying them safely.
hi
i remember reading something about the MU2 relying on spoilers only for roll control - being that these usually only deploy upwards it would be less responsive (maybe) ?
just a thought
aero
The company I fly for operates 2 Mu-2s. We have 2 captains that have 7000+ hours in the Mits. If you fly an Mu-2 by the numbers you WILL NOT DIE. The previous poster was right, roll is controlled by spoilerons. Due to this the single engine procedures are a little different. I believe a good percentage of fatal crashes are caused because JOe Blow with a fresh multi ticket can buy one, relatively cheap.
Aviation International News recently had a lengthy article about the MU-2. Paraphrased from that article:
It is true that it has a high accident rate, but it is hard to compare with other airplanes, as the number of hours flown is hard to pin down for the different types. Breiling did a study that came up with a 1.68 (accidents per 100,000 flight hours) for the MU-2 and 1.08 for the entire fleet of US registered turbo-props from 2000-2004.
The MU-2 also ranks higher than almost all jets when looking at data from 1964 to 2000. Only the Lear 23 with a rate of 1.89 toped the MU-2's rate of 1.88, with the IAI 1121 (Westwind) being next on the list. Except for the rest of the 20 series Lears with a rate of 1.04, all the jets have a rate below 1.0.
From the article, one of the biggest factors they came up with in the MU-2 accidents is a lack of simulator training. In fact, no pilot in any accident from 1996 through 2005 had successfully completed sim training. All the accident pilots had either received 'in-house' training or had used an independent instructor.
Most of the charter operators and cargo companies who use a MU-2 want to lower their cost as much as possible. So, you can see the problem. Sim training is expensive and the cost of the MU-2 is rather low. So it is possible to buy the airplane relatively cheap, then not have the money to get the proper training. Most of the companies who would use a MU-2 probably don't really pay that well either, so you will have lower time pilots with less experience overall flying a turbo-prop that is unlike anything else out there.
Although the accident rate for the MU-2 is higher than other types, from 2001 to 2005 three times as many people died in Cessna Caravan accidents (which has more than 3x the fleet size and flies over 3x the hours of the MU-2).
So, it looks like the MU-2 is not really the death trap that some portray it as. But, you better get the proper training in a sim. Mitsubishi has lobbied the FAA to mandate a type rating, but they have resisted. A SFAR mandating stricter training has been proposed (don't know if it has been implemented yet), and it has the requirement of recurrent training. This is actually somewhat more strict requiring a type rating, as those don't mandate recurrent training. The rule also has strict requirements for instructors, who have to have significant time in type.
