Calm Winds
You should just loosen up your spark plugs and keep the revs down below 3000.
:D
And a nice 0.0000000000000000000000000000000001:1 compression ratio :D :D :D
I went there today to fill up and it was $1.91 - 10 cents cheaper than everywhere else, so it's worth it. It was a feeding frenzy...people waiting in line. High octane was $2.05, which is what I have to get...stupid high-compression high-revving engines.
wtf is up with 91 octane being "premium" grade here???
in TX its 87, 90, 93
ALWAYS 93 octane for premium.
91 = sh*t gas
I think it's like that at all BP stations. I know in my town Shell, Amoco, Conoco, and Texico were the only ones that sold 93 octane.(that I can think of off hand)
Different companies put different additives in their mix. 91 with the right aditives could be comparable to 93. I don't know for sure, I've never looked into it that far. I just know that for my car BP's 89 and another station's 87 gives me the same gas milage. Other stations 89 not so much, but my engine is designed to run on 87, not the higher ones.
octane has nothing to do with gas mileage. it refers to the compressibility of the fuel before detonating. (eg - high compresson engines require higher octane fuel.)
Come on, I'm a car guy. I know what octane rating means.
As far as it not affecting gas milage, that is just not true at all. Engines make their best performance running on the octane rating the engine is designed to run. You WILL get less performance out of your engine if you run premium through an engine designed to run on the lower octane. Less performance means you have to push the engine little harder to get the performance you'd otherwise normally have if you put the right gas in in the first place, which equates to worse fuel milage.
I used to believe that running premium on the highway would get me better milage and performance on those long drives home. I never really checked to see if I was getting that result until awhile ago when I checked it out. I get 29-32mpg on 87. I get 26-28 on premium.
Yeah, like my "San Diego Weather, Entertainment, Beach, Culture, Edible Food Restuarants, and Sunshine Tax". It was exactly $200 per month (difference of my rent expense compared to Grand Forks) and WELL WORTH IT.
I agree, now get back to your studying. :p
I seriously hope there will be minimal wind again soon: I'm starting stalls next lesson (hopefully I get weathered tomorrow!) and extra wind is the last thing I need...I think I'll leave town so I can avoid this part of my flight training all together...
yeah but you can "hover" in slow flight :-D
