It is no big surprise that confusion might ensue when an answer is given, but no clear question posed. As many times as I've seen this "treadmill riddle" argued, at least the others began with a clear statement of the riddle before answers were posited. In this case, Texasspilot offered an answer before clearly stating the question.
The question, as I have seen it stated, is as follows:
This is not as much a question of aerodynamics or physics as it is a question of reading comprehension. Sentence 2: "The plane moves ..." No, the treadmill cannot, by definition keep the airplane stationary, because the question says, "The plane moves."
The treadmill matches the plane's speed, but in the opposite direction. No reference is made to wheel speed, or the treadmill matching the wheels' speed. The treadmill matches the plane's speed. If the plane moves at 5 knots, the treadmill moves at 5 knots, in the opposite direction. If the plane moves at 100 knots, the treadmill moves at 100 knots, in the opposite direction. If you look at the wheels, not because they matter, but because you're curious, you'll see they are spinning at twice the speed of the airplane, since the airplane is moving in one direction, and the treadmill is moving at the exact same speed in the opposite direction.
The plane moves . . . and it accelerates . . . and it flies.
