Texasspilot
didn't get much sleep but i've been arguing this question on another forum and then this hit me.
tell me what i got wrong here/
For your diagram to work the acceleration is solely coming from the treadmill - making it like a catapult on an air craft carrier.
If the wheels are going + at the same speed the treadmill is going - then you are going nowhere.
If they do it at the same speed v=0
And the wheels will be move - otherwise it will go off the end of the treadmill!
You need to think about it as 2 seperate objetcs -
The airplane when it accelerates on ground, and then think of of the consequences of the ground moving.
What if someone went out and bought all the leafblowers and fans in town and blasted them at the airplane on the treadmill?
How can the plane accelerate if the wheels aren't turning?
Lock the brakes on an icy runway and go full throttle on the engine. Will the plane move?
My feeble brain just can't understand how an airplane with zero movement over the ground (ie on treadmill that matches it's speed) can produce any relative wind.
The plane doesn't care what the wheels or the ground does just how much air flows over the wings. Imagine a plane flying at 100 K. into a 100 K. headwind. No relative movement over the ground but plenty over the wings right.
And in the normal example where the treadmill is going the other direction; the same thing. The wheels don't push the plane the engines push the air so the plane would still take off at the normal indicated airspeed. Higher wheel speed but, friction notwithstanding, everything else is normal.
Where did I go wrong?
