do you need to note everything done or just IPC-Sat?I've done IPCs over 2 weeks, flying several times including IFR cross countries. If I am gonna stick my name in your book saying you're good to go, you're gonna prove.. your good to go.
what i figured. usually i over-endorse/comment unless it is a BFR in which case i just write BFR-Sat (what I was taught in school). unless that is the wrong procedure as well? i have done 2 BFR's now, but never had one done for myselfI make notes in their "Notes" section or type up a small piece of paper saying what we did. Personally, I dont think you can NOT cover your butt enough especially during an IPC.
Protect yourself. It only takes a few minutes.
i was actually taught just the opposite. in case there in an accident say doing short field landings, they could come back to you saying you signed them off as "good to go"Not saying it was wrong but once you endorse a BFR/IFR, you've now attested to the student's ability. I make very detailed records. For instance, I record the maneuvers, ground lecture, landings, and make notes along the way. If, just IF, there was ever an accident, I want the proof that I gave a thorough and adequate review. Keep in mind the FAA doesn't provide "guidance" for a BFR so its up to you to provide adequate "evidence" of review AKA a detailed record in the event of an accident.
(Besides, what is the last real FAA enforcement action or lawsuit you've read about against a CFI for giving a bad IPC or FR? I haven't read my first one yet.)
i think this is the reason they said not to log anything additional. this came from a "gold seal" instructorIt can be a tough call. There's a theory that if you miss something in the record and that's the thing that's involved in the accident, you're screwed. So I guess one could say that badly kept records are worse than none at all.
I'm sure I conducted the XXX in accordance with the appropriate regulations and guidance as I always do" and leave them to find something to hang me with as opposed to me providing the evidence.
If there was an accident, do you think they'd just take your word for it and drop it? I doubt it.
Also, where do you find FAA guidance for BFRs?
