Bascuela
Now we all know to go below the MDA we need to be in a continuous position to make a normal landing. I’ve always taught that we you go visual (or the hood comes off) that you should level off and maintain that altitude until you can make a continuous descent to landing. This has always worked for me because students tend to go below MDA still at midfield downwind. Also, this works because you’re usually only at 500 – 700 feet HAA. Now for the question. What is your opinion of a MDA that over 1000’ HAA or even 1500’ HAA. From a LEGAL standpoint should you maintain that MDA until you can make a continuous descent (in other words no level off) to the runway. That can be tricky sometime because you might break out and still be 2 miles from the airport and really just want to set yourself up for a VFR pattern. I told my student this idea and I’m not sure if it is legally correct. I told my student that if he goes visual above TPA for the airport to descend to TPA and then level off until you begin a normal descent to land. Sounds good to me – but can one LEVEL off once going below the MDA for landing. Again legally speaking – not real world. – Thanks
