Flysher
Ive been reading a book called severe weather flying and it made some interesting points on the way we forecast and report ice. Basically the author says that we need to revamp the way we forecast ice. The current means, trace/light/moderate/severe are methods of reporting ice, not forecasting them.
What is a weather forecast really telling you when it forecasts "moderate" icing? Moderate ice is more or less defined as accretion that demands continuous use of deice/anti ice equipment to continue flight in that area of icing. The point he brings up though is that accretion can differ vastly between different types of aircraft due to wing shape, aircraft size, speed, etc... so what is a forecast report of moderate ice really telling you? not much in my opinion. A 737 may experience light ice while a light twin may experience moderate or greater. He suggests that they come up with some alternative way of predicting ice, such as probability of ice based on cloud type/temp/dewpoint/ etc... much like aviationweather.gov has now. Save the trace/light/moderate/severe stuff for pireps and extremely likely severe situations like FZRA.
I went to an FAA caravan winter seminar last night and it seems that they were using the terms trace/light/moderate/severe with regards to where the ice formed on the plane rather than accretion rate. They showed several slides with pictures of wings loaded with different amounts of ice and asked us to identify the severity of it. Several pictures had very minor amounts but were classified as severe due to the fact that the ice was on the unprotected area of the wing. Im not sure if this was a caravan specific way of reporting ice or if its maybe a new method that the FAA will try to implement.
Anyway just curious as to everyones thoughts on the items I brought up.
