Just got off the phone with a CFI and he thinks that I need to file an IFR flight plan when I go see a DPE next month for a check-ride.
For some reason I don't believe that to be that case. Anyone know if there is a requirement to file IFR for an IFR check-ride?![]()
It doesn't cost anything, and if you don't need it just don't pick up the clearance. . . Better to have done it if you aren't sure, IMO.
Make sure you use that explination when you tell off the DEYou can't legally file IFR as PIC until after your checkride. While you are PIC during the checkride, you still aren't instrument rated (which is required to file IFR) until the DE passes you.
That was exactly my point, but the CFI said it was mandatory. Here's the issue:
I'm training in Germany in a 172 that would be IFR certified in the states but because we are in Germany the plane is not legal because it does not have a DME with Harmonic Filtering (we use the GPS for DME). Also we are missing a second altimeter. I’m toying with the idea of having the DPE come to Germany but technically we can't even file IFR due to local laws.
I sent an email to the DPE... I'll let everyone know what he says.
That same argument would mean that a student pilot who is not rated in the aircraft at all, cannot act as PIC on a Private checkride.You can't legally file IFR as PIC until after your checkride. While you are PIC during the checkride, you still aren't instrument rated (which is required to file IFR) until the DE passes you.
. . . (as well as a DME arc he made up as we were flying along - that was fun).
