Aerodynamics Question for class
JaceTheAce
I was absent during the day the professor gave these equations. How do I find the solution and what are the equations?
An airplane has a published max gross weight of 4000 lbs, a published Vs of 68 kts, and a nL of 3.6.
A) What is this airplane's max weight Va?
Answer: 129 knots
B) What is the Va at 3400 lbs?
Answer: 118.9 knots
C) What is the new stall speed when it pulls 2.4g's?
Answer: 105.3 knots
I found out how to do the first problem:
http://selair.selkirk.bc.ca/aerodynamics1/Lift/Page12.html
But what about finding Va at 3400 lbs?
It's not. You see it's not actually related to anything. At all. Ever.
In fact stupid questions like this is one of the reasons I dropped flight.
Oh, come on - My employer wanted to know if I could create a V-N diagram for the airplane I'd be flying, as a condition of employment! Yours didn't?:sarcasm:
Hey Jace, I noticed no one addressed the third question for you, so I figured I'd give you a hand with it.
Set weight equal to lift and use the lift equation.
W=L=1/2CL*S*rho*Vs^2. You already know Vs^2 and the max gross weight (4000lbs.), so solve for that whole mess in between (1/2 *CL*S*rho=.8650519).
Then go back with that information and use a new weight (4000lbs *2.4 g's)= 9600lbs.
Put that back into the lift equation and use the 1/2 CL S rho that you just solved for and then solve for the new Vs.
9600=.8650519Vs^2.
Vs=Sqrt (9600/.8650519)=105.345
Oops. Edited the final formula.
