Do a little Googling on the Mitsubishi MU-2, specifically with regards to roll control, and you'll figure out his joke.Huh...
ROR.you mean airelons![]()
Newspaper reports have suggested the project could cost $1bn and the government may fund 30% of the outlay.
The MU-300 Diamond (which became the Beechjet) has many of the same characteristics. Although it looks like it has small ailerons, they are actually trim tabs. Spoilers are used for roll control. The gear doors are also huge. When they open, they are longer than the landing gear. If you have a loss of hydraulics the gear can be dropped by gravity, but nitrogen is used to blow the gear doors shut before landing.The MU-2 has a small wing, about the same size as a 172. They wanted to build a fast turboprop. It has double slotted fowler flaps along most of the trailing edge to provide the extra lift needed for landing. That leaves no room for ailerons, so that aircraft is banked with spoilers.
Dead foot, dead engine - No! Not necessarily in any turboprop as I understand it.
Probably sound advice if you're in a Caravan, but for multi-engine airplanes (at least all of the ones I've flown) Dead foot, dead engine is the way to go. Not busting chops here, just trying to figure out if I'm missing something or if its something special about the MU-2 and why.
It's something about the FCU fouling up and making the engine run like crazy. Maybe it's a Garrett thing. If your FCU messes up and makes the engine run in an overspeed, overtorque, overtemp, etc. condition, the airplane would yaw into the good engine. If you fixed it with rudder, your dead foot would be on the side of the good engine, and it would be very bad to shut down that one. Very bad. The only way to figure out which engine is bad is to interpret the engine instruments.
Mike
Id feel pretty good about flying one of their products, they make good TVs.
Even if you just left everything as it was on the throttle quadrant and skipped the gear up flaps up thing, identify and verify are still there and pretty important steps eh? I don't know anybody who feathers an engine too quickly. To do so is asking for mistakes to happen. I figure if my students are trying to feather within 15 seconds of an engine failure they're moving too fast.
Our pre-takeoff briefing goes like this: If you lose the engine while the wheels are down, you close both the throttles, land straight ahead and try to avoid anything on the ground. If you lose the engine while you're clean, you're going to do the engine failure flow and feather the engine.
If you need to get it feathered that quickly you were already dead.
