Requisition No: 223091
Job Title:
Captain Salary Grade: P09 Salary Range:
$1,190.38 - $1,984.23 Shift: 1 Location: Ellington Field, TX Relocation Package Available: Y Department: 0110500 - Aviation Manager: Dawson,James L Open Date:08/08/2006 Close Date: Qualifications:
Bachelor's Degree in aviation related discipline preferred plus 12 years related experience; or have 18 years of position related experience. Must possess and maintain current FAA Airline Transport Pilot certificate and FAA First Class Medical. Must have 3000 hours total flight time with 1500 hours as pilot-in-command, 1000 hours multiengine turbine experience, and 500 hours pilot-in-command multi-engine turbine experience. The candidate must have excellent interpersonal communication skills and be able to relate well with a variety of people. NA265 Sabreliner type rating preferable. Duties and Responsibilities:
Depending upon assignment, acts in general as Captain or First Officer. When assigned as Pilot-in-Command (PIC) for a trip, a Captain assumes command responsibility for the aircraft and crew, and is operationally responsible to the Chief Pilot and Director of Aviation. When assigned as First Officer, a Captain is operationally responsible to the designated PIC for that trip. A PIC's primary responsibility is to provide for the safe, comfortable, and economical operation of his assigned aircraft. When assigned as PIC the duties include, but are not limited to the following: (1) Remain current and qualified in assigned aircraft and be familiar with all regulations and procedures pertaining to its operation. (2) Review all maintenance documentation to ensure the assigned aircraft is airworthy. (3) Ensure that a complete preflight and post flight inspection of the aircraft is accomplished. (4) Ensure the assigned aircraft is clean, properly serviced, and stocked with all provisions needed for a flight. (5) Plan and review all aspects of an assigned trip and file flight plans. (6) Fly the aircraft and supervise the performance of the crew to complete all pre-flight, inflight, and post-flight assignments. (7) Maintain ongoing communication and liaison with Flight Scheduler regarding operational irregularities or schedule changes. (8) Provide for the servicing, maintenance, and protection of the aircraft at all times while away from home station. Coordinate closely with the Chief of Maintenance for advice and assistance with maintenance requirements. (9) Confirm that all required aircraft forms, logs, records, and reports are complete and accurate at the end of each assigned trip. When assigned as First Officer the duties include, but are not limited to the following: (1) Assists the PIC, as requested, in carryout of the PIC's previously defined responsibilities. (2) Personally checks the aircraft for airworthiness, required equipment, and cleanliness and reports findings to the Captain. (3) Monitors or conducts all aircraft and galley servicing. (4) Renders direct service to passengers and their baggage. (5) Makes required entries on flight manifest and aircraft logs.Performs additional administrative duties and special projects, as assigned by the Chief Pilot or Director of Aviation.
This position requires successful completion of a government background check before commencement of employment. If you are not a U.S. Citizen, this check could take up to 12 months to be completed.
Salary is weekly.
Job Title:
Salary is weekly.
