PSA CRJ-700 AA midair collision
The military has missiles that do this. Or whatever.
We know who meows because we know who didn’t meow.
Once someone did some stupid “welcome to RJ radio” spiel for like 30 seconds on guard. It was dumb and annoying. Then I switched someone to departure and that same voice acknowledged the switch on guard (with callsign of course). Gotcha bitch.
needs to be button on your console to tag this kind of behavior
not that you’re busy or anything
You would probably need only four or five repeat encounters over some time to make enough data points to statistically-eliminate all but the participating crew.
It starts off as midnight-5am then hour by hour we’re back to where it started eventually. Not to mention just the thought of an IROP will push a good amount of DCA arrivals to that hour. Will they cancel training flights during those instances?
Here’s an idea; slash a percentage of commercial flights if you want to do training in that area so bad. You don’t get both! It’s been proven both can’t be done safely. There’s 67 families that would like to have a word if you think otherwise. This stuffing 10lbs of sh*t into a 5lb bag then adding a bag of piss to it has gotten old.
I’m impressed that there’s talk of an ADS-B In mandate but…I doubt the airlines will let it happen 🤑
Same thing as adding in separate tcas displays when that became mandatory. And there aren't thst many jets running around out there that don't have the capability to display the data already. They just need a source.
