ahw01
NWS Discontinues Traditional Winds Aloft Forecast Tables
Pilots are being directed to graphical forecasts in place of traditional winds aloft forecast tables.
Idk I find the tables useful for flight planning the old fashioned way and in my capacity as a controller. Not sure how to find the same info without the table.FWIW, I dislike a LOT of the "web 3.0" changes made to aviationweather.gov, but these winds-aloft tables are an artifact of data being distributed via teletype, and better accessible presentation modes are commonplace now.
Ah, I assumed the replacement tech included an API or TFTP for an internal file format or something.The textual, tabular data is easier to integrate into other things though. Like flight planning software.
Well you should. Maybe you have enough volume and you get pireps, but I like to know when the wind is drastically different on approach than it is on the field and it happens. Some places I've worked more than others, but it happens and it is good to know about.Do you really use them in your capacity as a controller? I sure don’t.
I just look at their groundspeed. You know someone is doing 250 indicated. Ground speed shows 300. 50kt tailwind.Well you should. Maybe you have enough volume and you get pireps, but I like to know when the wind is drastically different on approach than it is on the field and it happens. Some places I've worked more than others, but it happens and it is good to know about.
you said the quiet part out loudThat's my story and I'm sticking to it.
If they are at 20,000 feet on a standard day, and indicating 250 knots, their True Airspeed is 342 knots.I just look at their groundspeed. You know someone is doing 250 indicated. Ground speed shows 300. 50kt tailwind.
So if they are showing 300 knots over the ground, then they have a 42 knot headwind![]()
