F-117 added to Udvar-Hazy
One of the things you'll notice in the photos of my jet 85-0818, is how the jet looks somewhat ratty looking, and with strips/pieces missing underneath the tail number of the vertical stab, as well as white chalk looking stuff around the cockpit. This was not the fault of any kind of maintenance, but merely a limitation of the jet itself.
F-117s at home station were not kept in a full combat-ready status. Their weapons attack systems were fully ready, but the jets themselves had to be prepared for combat if the call came, in terms of the stealth items and specifically the external coating of the fuselage. With these first generation stealth jets, the outer coating on the jet....the RAM, or Radar Absorbent Material.....came in "sheets" and had to be placed onto the metal fuselage of the jet by trimming to fit, then gluing into place, with a fairly long curing time. Because of this, bits and pieces of of RAM would come off inflight often, and it was alot of work to maintain it. To do so would have far too many jets out of service and far too many maintenance hours dedicated, so RAM was only replaced in larger sheets if need be. Smaller areas of missing RAM were either left missng temporarily until maintenance could get to it, or were filled in with the RAM putty, resulting in the worn look that some of the jets had, even though that was only a look. When off to actual combat or to an exercise like Red Flag, the jets were fully prepped and looked pristine, with their RAM coating perfect and Radar Cross Section for that particular tail number well within specs.
The RAM itself was one of those items that had to be removed in order to access panels and such on the actual airframe which were located underneath the RAM on the actual metal fuselage. Looking closely at a 117, everything is underneath that RAM, and there are no rivets, screws, or anything that protrudes when the RAM is on. Antennas retract flush into the fuselage when not needed, etc. On one of my side console pics, you can see a switch for extension/retraction of antennas.
This is what an F-117 with no RAM coating applied looks like. It’s just an aluminum aircraft with some minor olastkc parts and a funny angular shape.
i posted a picture of this in my initial cockpit photos of the left console and left sidewall area of the cockpit. Having seen a few F-117s that have been sent to museums, i’m fairly surprised that this was left in the cockpits. Granted, all display F-117s are displayed with canopy closed, but given what this control head was, it still mildly surprises me that these were left here, even if there is no indication as to what they were.
When F-117s are sent to museums, they first have to be demilitarized by Lockheed and USAF personnel. Major things that occur in the demilitarization process is all classified RAM coating is stripped off completely, to where the jet is an aluminum shell. Certain airframe components such as leading edge wing and engine exhaust area components are removed and retained. Engines are removed as are some components from the bomb bay. Ejection seat in the cockpit is deactivated, as is the tail hook actuation system and detonation cord at the hook panel as shown my above picture. There are some other still-classified items that i’d love to gain access internal to any of the museum airframe fuselages and see if any of those are left inside there or any remnants of same. Surprisingly, the cockpit is left fairly untouched in terms of instruments and displays and such. No operating manuals, aircraft manuals, or maintenance manuals are sent with the aircraft. The museums receive a stripped down shell
of an aircraft that is missing exterior parts. Museums have to spend their own time and money reassembling what it sent to them, manufacturing wing and fuselage leading edge parts to reconstruct the airframe fully, painting the aluminum airframe flat black, or in some cases gloss black for longevity, and reapplying markings. It’s a lot of work to get an F-117 display ready after receiving one, as they don’t show up to a museum in any kind of ready to display condition.
In the photo here, was the nuclear weapon control panel. It was installed in the F-117, for a nuclear strike capability and mission the F-117 never ended up having. The F-117 never sat nuclear alert and there was never any nuclear munitions carriage/delivery publication or checklist that i ever saw, neither current nor historical, even though in theory it was nuclear carrying carriage/employment capable. Munitions carriage/delivery publications are separate publications for non-nuclear and nuclear munitions, even for the same aircraft. And finally, there was no Personnel Reliability Program (PRP) for F-117 flight or ground crews. such that crews involved in nuclear or NBC-related weapons programs are mandatory to be a part of.
The panel still had power to it, and could be switched on, and the left and right LOCK lights would come on. But that’s it, if there was no nuclear weapon loaded and no interface with the Stores Management System. Even if you lifted the red guarded UNLOCK cover and flipped that switch, nothing would happen and nothing would light up, as there was no weapon omboard to interface with. One interesting thing was, that the grey three-position switch that toggled between the left and right bomb bays; there was another grey toggle switch just to the left of it that has been removed and it’s markings erased on the panel, that i cannot remember what it was for or what function it performed with the weapons bays.
About 6 months before i finished my tour in the program, the F-117 finally received the ability to drop GPS-guided bombs. The F-117 program has already received its official order to end, known as DOD Program Budget Decision (PBD) 720. PBD 720 directed the end of a few programs across the board in the military, and cuts in force personnel; the entire F-117 program being a significant part of the PBD 720 decision. However, as the plans for the installation of JDAM capability had already been contracted out, the conversion had to be legally completed, even though the jets were knowingly getting retired.
The old nuclear weapons panel would now become the interface panel for the Joint Direct Attack Munitions) JDAM bombs, the only one of which we carried being the GBU-38, which was essentially a Mk82 500lb dumb bomb with a JDAM GPS guidance kit strapped to it, it’s only form of guidance. Our only other GPS bomb which was rarely carried. as it’s guidance package was expensive, was the EGBU-27. This was a GBU-24 2000lb Laser Guided Bomb with shaved-down tail fins so it could fit in the F-117 bomb bay. The GBU-24 Paveway III munitions had not been in existence when the F-117 was designed, and thus the bomb bay wasn’t built large enough to accomodate the large fixed-tail fins of the PWIII fin kits. Only the collapsed fins of the Paveway II munitions were in existence at the time. Because it was an EGBU, Enhanced GBU, not just a GBU, it had two methods of guidance. For VMC weather conditions, Laser was the primary guidance. However for bad weather where the target could not be visually seen in order to be laser illuminated, the EGBU-27 had GPS guidance. GPS guidance was good, but not as specifically accurate as laser guidance was, in terms of hitting a specific point of impact such as a particular window of a particular side of a structure/building, as opposed to just hitting a building itself.
The JDAM capability was nice for the F-117, but entirely useless for an aircraft and program that was knowingly being retired in about a year after the installation of this capability. I flew for few months practicing JDAM munitions delivery and using this interface panel, though i never dropped an actual JDAM bomb from the jet before I finished my time in the program shortly after these were installed fleetwide.
