Learjet 60 crash in West Palm Beach
One more thing from lining up the radio calls with the ADS-B. To my ear, her voice changes significantly between the 10,000 fpm call and the 20,000 fpm call. On the first she's energetic and alert but composed. On the second she sounds much more alarmed, while still having the presence of mind to keep working the radio (using the call sign, for instance). The ADS-B data changes in those same seconds.
Times are UTC and assume the LiveATC archive starts at exactly 17:30:00. Path angle uses ground speed and Mach is rough, with wind unknown and temperature taken from the crew's −47°C report:
- 17:48:30, "Mayday", 10,000 fpm call: −14,016 fpm, path 16° down, no turn (track 099°), about 0.84 Mach.
- 17:48:36, "[Declaring] emergency": −19,904 fpm, path 22° down, first movement in the track, about 0.88 Mach.
- 17:48:41, 20,000 fpm call: about −20,700 fpm, path 22–23° down, turning right at 1.2°/s, about 0.90 Mach.
- 17:48:50: −20,864 fpm, path 22° down, turning right at 2.5°/s, about 0.90 Mach.
- 17:49:03, "twenty two thousand feet ... banking sixty": over −31,000 fpm, path about 35–40° down, turning right at 2–4°/s, about 0.91 Mach.
The jet appears to go over its Mach limit at about the time of the first descent and Mayday calls. Mmo is 0.81 Mach from 26,750 to 37,000 ft (Learjet 60 AFM FM-123, Change 37, page 1-9, a 2009 revision; the FAA data sheet charts the same limit, TCDS A10CE, Rev. 67, page 23: Dynamic Regulatory System ). Assuming no wind, it passes 0.81 at about 17:48:27, about when she first calls the descent. Assuming 20 kt of headwind or tailwind moves that to about 17:48:21 or 17:48:32, still after the descent began at about 17:48:16.
The right turn first shows at about 17:48:36, about when she starts to sound more alarmed, within about a second of alignment. Before that the jet is presumably in a wings-level nose-over, with load well under 1 g (our rough estimates run about 0.1–0.4 g). After it, the bank is building at about 1.1–1.4 g, and the speed is near 0.90 Mach. Those load figures are estimates from fitted ADS-B, not measurements.
The descent rate climbs fast until about 17:48:36, then holds near 20,000 fpm until about 17:48:50 before steepening again. Her 20,000 call falls on that plateau and that number matches the ADS-B data.
What this doesn't show is what caused the change in her voice from call to call. She could be reacting to the overspeed, the rate, the roll, or recovery inputs that weren't working. It's tempting, but obviously still premature, to tie the start of the bank to the left elevator coming off, since the NTSB says most of it was found 1.3 to 3.8 miles from the site. A separation at that moment would need about 2 miles of drift or carry, which is possible, but nothing shows it. Also, of course, a right spiral isn't necessarily due to a left elevator separation. High-Mach wing drop, uneven ice or damage, or a small roll that a pull then tightens could all do it.
Same caveats as before: a rough outline, not a forensic analysis. Still using well-managed AI assistance; numbers and calculations are checkable against public data.
Pete
Are you under the impression that you’ve provided new insights?
Once this plane turned into a
Pete
You haven’t added anything to the conversation.
Pilots rush the recovery and accept sloppiness. Asymmetric G loading is bad enough in fighter jets, but worse in fatty jets that aren’t designed for even moderate symmetrical G loading, much less asymmetrical. It’s a good way to unintentionally bend or break things off of your aircraft during a nose low recovery, which will only make your manageable situation worse,
Yup. Just have to tell them don’t do a negative G push over to the horizon from a nose high condition, those Gs aren’t fun, nor a very effective method to get back to the horizon. Even if the jet it’s seriously nose high, say above 45 degrees, and rolling, one can even complete the roll to the nearest horizon with a little pro-rudder back to the horizon upright instead of trying to stop the roll when it’s past 90 degrees and then attempting to reverse it the long way back to 90 to then try to slice the nose to the horizon. These are just things most pilots don’t receive any basic training in. So long as control input is smooth and kept within G limits, the airplane doesn’t know or care what it’s attitude is…Bob Hoover used to demonstrate that in the Shrike Commander and Sabreliner……though getting back to upright flight in a non-aerobatic plane should be done with some urgency and not dilly-dally’d.
If I were king for a day, I’d have all fixed wing pilots go through a mild centrifuge training profile, probably to about 3.5-4Gs tops, just to experience what that weight loading feels like.
I just had my biannual upset recovery in the L-39 and Saberliner. I wish more pilots would get this training and see what the limits really feel like. Great demonstration that even at extreme pitch and bank angles, you don't have to get near the +2/-1 G limitations to have a successful recovery.
Not typed, but I do have some LJ60 training materials at the house. I'd bet Lear-Gates-Bombardier didn't publish performance tables for icing in -47c. If anything, there's probably a note/ caution/ warning/ limitation that prohibits operations in such conditions.
From what I've seen in our Bombardier docs, any SLD condition requires an immediate escape. I assume other manufacturers have the same warning.
CHECK MY WORK !
AI DID A GOOD JOB !
OSINT !
the problem with AI people is that they just invent problems that don’t need solving to prove that their Clippy works sometimes
I had chat do my receipts and expense reporting for me for the first time. I just scanned all the receipts into Google Drive, told it to compile them in statement order and match them.
Given that I had 3 weeks of Italian and German receipts that were in euro with a statement in USD, and they were all in languages I don’t read… it was amazing.
I am an AI convert now. No more getting yelled at for delayed expense reporting!!
I’m not aware of a part 25 certificates airplane which is approved for them or for several icing. The certification only requires that the protection works well enough for you to exit icing… not continue operations.
We use Ramp, which is pretty sick. All I have to do with it is take a picture of the receipt with my phone and it categorizes the receipt to where it needs to go and creates the report. Payouts happen as soon as my boss approves the report.
Corporate card for us… don’t need payouts etc, just to submit/reconcile.
I keep seeing coffin corner plausible cause pilots online, but I doubt it. If they were doing FL410 just before the FL panhandle just fine, with enough margin that allowed them to be there, 350 would definitely be fine, and a climb to 370 should be fine.
Probably much more to do with icing, and LOC-I with an improper recovery that leads to inflight breakup.
Someone still fly’s a saberliner?
