Trans-Aero Medical E90 King Air crash
I feel for the crew. They asked about GPS jamming. Wonder what the reply was? ATC is likely to not read page 2547 of the notam, either, but you'd think some heads up between the military and ATC on something like that would be nice.
FWIW when I’ve had gps drop off over that part of the country ATC generally knows it’s going on.
Obviously I only "love"d this because I'm unlikely to get a checkride from you...
Ha! All checkrides, we have to give an inadverent IMC scenario. I always give it to lead to a ground-based approach of some kind….ILS/LOC/VOR, as described above….; then they get a second approach somewhere else that’s GPS-based.
The ground based approach is always raw data, so I know that they can go back to basics of either green needles and nav frequencies, or basic six-pack usage (for the non glass birds). The GPS-based approach is where I can see that they can load up a clearance as a flight plan in the Garmin along with an approach procedure, build/brief/bug it, and execute the magenta. Always make sure to take them to airports they haven’t been to and approaches they haven’t seen, hence why my rides are longer than the other check pilots, due to the cruise time to get to the airports and approaches that no one goes and does normally, like to garden spots such as Gila Bend.
Agreed. It’s an ongoing NOTAM with various active times from out of White Sands there. Cherokee control lets ZAB know when it’s going on and active. To what degree jamming testing is being done, or what specifically is being analyzed, ie-partial, full spectrum, or something else, and whether they can limit the affected radius of it from the source, I do not know. I do know that our jets had an early anti-jam/spoof software cape of some kind that was being tested/used. I was based out there for 3 years, 20 years ago, and the testing was being done back then too. I never thought during the times I was working in the ATC tower to pick up the landline and give a call to Cherokee and ask what exactly they were doing, if they could even say or if they even knew, but it was just one of a number of weird test programs going on out there at the time, stuff I wasn’t read into due to having no need to know.
Presently, and more so in the near future, flight crews need to be prepared to complete a flight during a complete GPS failure in a non-RADAR environment.
The time to brush up on VOR ops and Mandatory Reporting Points is now.
Airbuses HAAAAAATE GPS jamming becuse it causes cascading errors and ECAMS.
It appers the military does it with reckless abandon and there needs to be a conversation about it.
Good thing we have a multi-chain LORAN network already established that can act as a backup….oh wait.
Well, hopefully there’s a MON VOR somewhere, or a at least a compass locator.
I read in one of our documents that the Iranians were jamming or sending false VOR signals as well and we couldn’t use DME/DME or VOR backup for the INS.
The issue on the Airbus is that if you don't catch the spoofing in time and protect your position, the IRU data gets tainted by the bad GPS data and then you are honked.
This was an issue with all the spoofing in the Middle East a few years ago. I think the guidance back then was prior to entering an area of known spoofing to deselect the GPS from the IRS.
And I agree, I’d have no problem flying around the world IRS only, wouldn’t use it for approaches though.
Wouldn’t or couldn’t?
We do the same thing. Oddly enough our NAVRAD is inhibited by default, so we have to turn that inhibit off.
Depends on what the approach requires. An RNAV overlay of an NBD approach is probably going to have a lot more allowance than a .15 RNP-AR approach. The airbus is pretty good at telling you your level of position accuracy. I assume the other OEMs do a similar thing.
IRS is only for RNAV 10 or 5.
