Bangor Maine - private jet w/8 crash
As a ex corporate guy who did this exact kind of flying…aka, small part 91 operation with 1 plane.
No one uses hold over times and nobody has an app for that.
They literally had no idea. 100% guaranteed.
I've dealt with a lot of crews and different levels of experience.
A considerable percentage of them had insufficient understanding if icing operations.
Many haven't used holdover tables since their college days.
I've flown in a LOT of icing conditions... I mean ALL of them.
I've made bad decisions too.
Made a take off in a turbo prop with a frosty wing.
Book stated that departure was allowed if the frost was smooth or polished.
It flew... but it was not pretty. It was a BAD mistake.
If anything went wrong, engine failure, wake turbulence, wind shear, or even heavily loaded, I would have been [violently fornicated]
A swept wing on a modern airplane is way worse.
Having flown earlier in the day and a snap roll on airport property does point towards an asymmetric lift issue...
Not helping the case for us from having to do the “walk of shame” after deice….
Tbh though, i REALLY do not get why people make a big deal about deice in 121. Youre paid by the minute, you dont pay the bill….just do it thoroughly and right ffs. If in doubt, even the slightest, call iceman, run the procedures and checklist. Of ALL the things people are concerned with “newer” FOs being exposed to before upgrade, why the f do we make deice a big deal?
I don’t enjoy de-icing but I will when there’s any doubt or sign of contamination.
It’s like I really hate waking up in the middle of the night to pee, but the alternative is not acceptable.
-17C. At 3/4 SM that's moderate snow if we derive it from prevailing visibility. Just looked it up for curiosity's sake and the holdover time for a generic Type IV in those conditions is 2-7 min. That's some nasty weather.
One Twenty Weenies can usually get better than generic. Cryotech Polar Guard and Clariant Safewing have much, much higher holdover times than generic type IV.
Have you ever de-iced in a non-121 airplane?
No. Take a seat and wait this one out.
Relevance? Have flown and deiced in a CRJ-200 many times, which is a similar airframe supercritical wing design.
Can I ask your experience in aviation and deicing?
I have an app for that. Is there a particular question I can answer? At -17C night snowprevail vis 3/4SM as mod intensity, generic type IV is 2-9 min and Clariant Safewing is 6-20 min. So about 2-3x more. Even better is Cryotech Polar Guard at 20-40 minutes.
Again. Did you have a particular point? Or a question?
So you’ve only operated using an FAA-approved company ground icing procedure. Very different from dealing with a FBO and having to use AFM procedures (for starters, HOTs are advisory only on the NearJet I fly and we have to do a tactile check within 5 minutes of departure).
Relevance?
The relevance is that you professionally have flown very few aircraft, and your scope of experience is entirely within 121.
It has been two weeks since my most recent de-ice, and I have been to that airport in the winter. It would take some research to confirm, but I might have even de-iced there. I do recall one trip I had an AOG event and worked with the FBO to get maintenance on the field to resolve the issue.
Sure, do you know what de-ice fluid, mixture and temperature was applied?
You might be surprised to know that not all FBOs use generic SAE type IV (that's SAE AMS1428M, in case you're wondering), Safewing is more common than you think.
If anyone wants to read up about the specification required for all type IV fluids:
Um, ok?
And all this started with me literally saying One twenty Weenies having access to better/more options of type IV.
Was that wrong? Sounds like you and CFI are making the case.
How is this relevant to the generic commentary that 121 has access to different (better types) of type IV?
We did DTW-BGR in the NWA days and deiced there too. Again I don’t see your point.
Yes, they give us that info.
Again I don’t see your point with the quick dismissal stat-in-your-lane and sit this out comment based on a simple commentary about better type IV access for 121.
Um, ok?
Was that wrong? In this case yes. BGR airport runs the De ice for both GA at 121 at the same pad.
But you wouldn’t know that. So maybe ask the question next time *before* the answer
I don’t even care if your stat is true, I’ve embraced it.
That's from hazy memory of my *extremely* dog-earred copy of a collection of Flying Magazine "Aftermath" columns (back when Flying Magazine wasn't just basically an advertisement for ways to kill yourself if you're rich). $10 says that particular article was written by Peter Garrison, he was the best.
Haven't seen that book for ~15 years, but I still (sort of) remember things like this. Now ask me what I ate for lunch yesterday. No idea.
That was all small points to lead up to it’s the same de-ice team at BGR for 91/135 & 121 aircraft and you would’ve known that if you’ve been paying attention.
