Soul Brotha'
Off to go do Black guy stuff
Well, he’s wearing a pilot shirt with 4 bars, so he’s legit.  I bet he’s wearing boxers.
			This is all I see when the experts pop up on YouTube:
View: https://www.instagram.com/reel/DLDixNEhwHe/?igsh=dTR1MXdtbzVuYWN4
I had a friend that wore pilot shirts like that. I asked him if he was aware that they made them in adult sizes.Seriously. This tight fitting pilot shirt thing needs to end. It doesn't look cool or professional, women think the pilots wearing them look like creepers (according to my wife). Based on his choice in shirts, he is not a credible source for anything.
There’s a line between this and the ballooning drape tents that I’ve seen some pilots wearing. It’s really not hard to find a good-fitting shirt for one’s body type.Seriously. This tight fitting pilot shirt thing needs to end. It doesn't look cool or professional, women think the pilots wearing them look like creepers (according to my wife). Based on his choice in shirts, he is not a credible source for anything.
@derg who's the "influencer" that got fired from Delta and now she's an "expert" since she has flown IRP in a widebody. She had a disgusting linkedin post with her take on the accident. Is she a known commodity?
Linkedin keeps trying to get me to connect with her and I'm too dumb to figure out how to mute her.
Did Boeing sub out the seats to Cessna?Rumot going around now is captains seat slid back on rotation and he pulled the thrust levers to idle with him.
Tight shirts are for fat people and male escorts. And that video is AI filtered as hell.
That rumor was false apparently.
I’ve never understood accidents where pilots did not firewall everything they had in order to avoid crashing / ground contact.
C5 Galaxy - thrust lever swap, effectively taking them from 3 working engines to 2. But only 1 engine was truly down, 3 were good. If you’re about to crash, why not firewall all 4 levers forward?
Air Florida - improper thrust set due to probe icing. If you’re about to go down, why not firewall both engines?
Transair 737 HNL. 1 engine fail, working engine was idled accidentally. But at no point was either engine shut off. Gliding to the water. Water contact imminent.. why not firewall both engines?
In all 3 cases, grabbing all thrust levers and shoving them full forward could very well have saved the day. Nothing is worse than hitting the ground and crashing. Push ‘em forward, every thrust lever.
 . Gimme N1 or, even better, on the Trash Panda, N1 + percentage of maximum thrust.
. Gimme N1 or, even better, on the Trash Panda, N1 + percentage of maximum thrust.IMHO there should be four (male) pilot shirts. 1) Fat, 2) Pear-Shaped, 3) Skinny, 4) Ripped. In that order of production priority, for obvious reasons. Assuming we don't do the sensible thing and just go to Flight Suits (RIP Toddler). But in an astonishing feat, they keep shipping us stuff that doesn't fit *anyone*.
as it should be…TPE331 had percent RPM and percent torque. Perfect. And the computer adjusted the temp reading so your redline was always in the same place. Then I flew Pratts and it was all like “1875 RPM? 37 PSI? WTF do those mean? Are those good numbers or bad numbers? ITT limits is 840 degrees, except when you’re doing a start, or cruising, then it’s variable depending on the phase of the moon…..Which is why I hate EPR!. Gimme N1 or, even better, on the Trash Panda, N1 + percentage of maximum thrust.
				 www.seattletimes.com
At least I look fantastical!Tight shirts are for fat people and male escorts. And that video is AI filtered as hell.
I’m just complaining about the format/protocol used in markings/rangesI mean it’s not "my" plane, but I don't think id care too much about redline anyway, in that scenario. Better to get away from the ground right now, and have one of them overtemp/blowout once I have some altitude to use.
