Kingairer
'Tiger Team' Member
I let AI invest for me so when AI replaces me.But if you put your money in various funds...
For now.@AIAeroscan see...
A DANGEROUS IDEA: Removing Pilots from the Flight Deck
Pilots around the globe are unified in the fight against reduced crew operations.safetystartswith2.com
You may laugh, but I fully expect AI to take a huge chunk out of the mid-tier or higher managers very soon.Let's have AI replace low-skill workers like CEOs and VCs first, and we'll evaluate from there.
I spent several hours today writing code for this open source product my friend is working on to make an AI project manager... Marshall Brain's "Manna" short story is probably closer than we think.
capitalism has no intrinsic goals other than to seek equilibrium points in the market. the capitalists have goals, and all of their goals are to become monopolists.Really, I'm just patiently waiting for someone to explain capitalism's end goal to me.
Work hard, Make money. What is your solution? Do you like communism, because that's been tried repeatedly and always ends up in totalitarianism. What we are currently seeing is meritocracy being stripped away as a founding principle. Smart people that work really hard should be rewarded not canceled. But you've also said you think there should be open borders, how's that working out?capitalism has no intrinsic goals other than to seek equilibrium points in the market. the capitalists have goals, and all of their goals are to become monopolists.
AI could be transformational in troubleshooting thought.I fail to see where/ how AI will aid in maintenance, true hands on maintenance. Is ChatGPT going to crawl up into a center section with a torque wrench, insert the SD card for a 28 day database update, or leak check a manifold, pack wheel bearings in its palm.
Maybe upstream there are ways to utilize it with respect to writing manuals, or development of procedures, but to the technician that’s getting their hands dirty on the hangar floor or out on a handstand doing line maintenance, I just don’t see it.
One use case is allowing pilots to send a picture of a bald spot on a tire or a dent on the airframe to the AI program and it will tell them if it's within tolerances.
Troubleshooting is a big one.I fail to see where/ how AI will aid in maintenance, true hands on maintenance. Is ChatGPT going to crawl up into a center section with a torque wrench, insert the SD card for a 28 day database update, or leak check a manifold, pack wheel bearings in its palm.
This is a fantastic use case, there's a lot of stuff like that that could be similar.One use case is allowing pilots to send a picture of a bald spot on a tire or a dent on the airframe to the AI program and it will tell them if it's within tolerances.
Some really smart people are working on this, and while I am not clever enough to do that, I routinely use AI to write boilerplate code and to help me refactor code I've used to generate other AI stuff.Can you design an AI based system to design the AI based system you are designing?
Most radical case would be where the AI has looked at data for the type of airplane you're operating and can give you better analytics that can help you reduce down time early:That I could see working, digital analysis of components to determine within limits. Although with how sensitive tire damage is given the Concorde and Nigeria 2120, I don’t know if we’re there yet.
Have you ever worked on or managed a fleet of airplanes? A lot of your great ideas already exist and are not only used, but depended on daily. We already have what you're talking about, including reminders about upcoming inspections and alerts about the critical dispatch component list (it's a list the manufacturer publishes that lists which components have caused canceled flights fleetwide and the pertinent details). Like @CFI A&P said there is no replacement for the people on the floor, I can get a lot more info from 10 minutes on the floor than 2 hours online or on the phone. I've told the story of pulling a G-IV PDB and finding a 1/4' drive 1/4" socket floating around inside it, how would AI anticipate that failure? If we had taken the time to tell AI what the issue was, it would've taken the same amount of time as it did to look at the WDM and come to the same conclusion, something's wonky in the PDB and we better pull it out and have a look. The other part is the human factor, if you start to depend on AI to do your critical thinking for you your mind will atrophy. I hate inspections and routine MX, I love troubleshooting.Troubleshooting is a big one.
I see something like this being the case for difficult to troubleshoot weird intermittent problems: "Hi there Mechanic Bob, I've looked at the current statistics and 92.5% of similar squawks in my database were related to the primary buffer panel (see figure 7-8). In fact, one PIC even said, 'I can't believe that the primary buffer panel has fallen off of my Gorram ship!' shortly before similar electrical issues started to occur. Since all the problems recently have been seemingly unrelated, that is statistically the best choice; there is one wiring harness and cable (see figure 9-4) that goes through the primary buffer panel that connects to most of the systems that have been recently written up multiple times. Maybe you should check to see if it's worn out?"
Another thing I could see is walking you through a repair you haven't done in awhile. "Nice to see you again, ok, I know you haven't done this in a while, but do you need help remembering what to do first? I can give you a checklist whenever you like!"
Mostly, I think what you'll end up doing will be largely the same, but the access you have to information be increased amazingly.
"Hi Mr Director of Maintenance. The N12345 is not scheduled to have <a weird component> replaced for another 50 hours, however, when I consult my whole fleet records, 99.6% of them have failed within 200 hours or more before they were scheduled to be replaced. You should have a technician check it or replace it early on night shift soon, that's possible on the weekend of 5-18. That should save you AOG time as that aircraft is not scheduled to fly the following morning if you find bigger problems.
Looking at next weeks schedule and the typical scenarios when other airlines have had to squawk that component, that airplane is likely to be at an outstation where we have contract maintenance. Doing that repair at an outstation would likely be twice as expensive as doing it this weekend."
I know mechanics are always doing that sort of calculus in their mind, but imagine having a polite old-timer advice guy who'd seen everything 100 times and while he was too old to reliably turn wrenches, he knew practically everything about the airplane and would patiently walk a mechanic through the most complicated repairs and could also advise management on the best times to do maintenance, etc.
