Roger Roger
Bottom of the list
me after hearing the 14th different tech-cedure lecture about autobrakesFull yeet on the TRs and slam on the brakes! #thisistheway
surely this is a problem that will get better with PBSLet us not question why he is the #6 CA in base and still bidding the milk run and then bitching about it
What are AUT-OH-BRA-KAYS?me after hearing the 14th different tech-cedure lecture about autobrakes
Honestly at this point all I’m sure of is that I point to them on one of the checklists while the captain says “RTO”What are AUT-OH-BRA-KAYS?
I mean I kinda get the first part, lord willing that will be me one day, but if i ever get like the second part I hope I have the money and the guts to just retirehaha it only gets better when these guys don't specifically ask for those trip #'s in PBS. It's airline Stockholm syndrome
They pay me 5:15 for this (used to be 5, nobody wants to work anymore!), I need to do it faster than that, if I stop by the 6 board, I can block in sooner........why do these brakes chatter so bad?
Says the boomer CA who just landed on a snowy contaminated short runway with a 50 kt crosswind, as they release the TR handles from a death grip at 7 knots
Let us not question why they are the #6 CA in base and still bidding the milk run and then bitching about it
We got onto other tangents before you even heard half of it last night!What the deuce is happening over there?!![]()
You need not worry about it derg, sometimes the first cabin floods, sometimes poop instead, and once in a while, rotten fish fall out of the ceiling or an engine cowl blows a gold medallion member out the window. It's just domestic stuff
FLY DELTA JETS
“TRS ARE SUPPOSED TO BE STOWED BY 80!!!”-my boomer captain, probablytalkingyelling over a taxi instruction
I thought that was kind of dumb as well,Dry runway. 12,000 length.
Cowl latches not secured.
You land, STOP using TR on the affected engine!
You are damn guaranteeing ripping that thing to shreds and sending it places you don’t want (eg, fuselage).
wait people don't come to a full stop at max TR? I'm not sure what planet I'm on anymore
gas is already paid for bro, I aint running off the end
Laces out!Latches…latches…latches….oh and LATCHES. Check them from four angles every flight. Call me paranoid; thats because i am.
They drilled checking the latches into me during my time at Mean Green, after that particularly spectacular one they had in Vegas. Now it's just become a habit on anything I fly.
Unfortunately, a misunderstood subject that has led to several seized hot brakes and planes that had to be towed to the gate.
They finally put a memo out about AB usage and what the best method is for the NG for coolest brakes.
I’ve stopped using ABs unless it’s a short runway, contamination, or a crosswind. Detent 2 or Max reverse until below 100 knots, and then come on the brakes for one smooth application and make an appropriate turnoff.
The MAX “recommends” using AB 2 or 3, but honestly, you can’t go wrong with the same thing. Unless those 3 conditions, I leave AB off. Reverse until below 100 knots, and then one smooth brake application.
For brake plug fuse calculations, you’ll see the performance handbook reference a brakes on airspeed. Below 100 knots, brakes on airspeed is a far different scenario than brakes on at 120 or 140 knots.
KE = 0.5 x mass x velocity^2
That square velocity function is what some just don’t understand. You have far more KE at 140 or 120 knots than at 100 knots.
Using AB 3 or MAX unless a short runway or contamination, on a hot day is just unwise.
I’ve had one FO who consistently tried to do AB 3 each landing, regardless of length, dry, winds. I blame training. I remember being told that “if you’re gonna use AB, 1 or 2 is useless. Take 3 or MAX.”
I’m sorry, but that’s shows a complete misunderstanding of how AB works as a deceleration rate. And an idiotic statement to make as an instructor.
