Review of witness video revealed an in-flight fire near the area of the engine exhaust and the tailboom attach point. The tailboom partially separated in-flight and the helicopter descended in a right spin
- Report:
What's so dangerous about working on helicopters?I used to work on helicopters of the single and twin engine variety built by Eurocopter. Wonderful machines, but inherently dangerous by nature. I moved on, I don't do that anymore.
Funny you ask
We just had a guy who was preflighting on top of one of the helos, when another guy preflighting the tail absentmindedly rotated the tail rotor by hand to check the other blades, without checking if anyone was in the way, which rotated the main rotor behind the back of the guy on top of the cabin who was looking inside a panel, and he almost got knocked off the roof of the bird onto the concrete when the leading edge of the main rotor began shoving him off the roof.
Are there mirrors on a 135 that provide a rearward view? Seems most helicopter mirrors I’ve seen provide a downward view for landing or sling ops.
Dang. It seems like adequate monitoring would be cheap without a big weight penalty.That was fixed later, but it was an excepted risk to operation for the Army to have no fire monitoring in an area made out of magnesium.
Look, we don't call you names around here.......... bad enough in anal airplane,.....
A fire is not one to mess with though. It’s a Land Immediately EP, like I mentioned before that’s a luxury fixed wing doesn’t routinely have.
I alluded to the same thing in an earlier post, somewhat lightheadedly. With a helicopter fire, returning to the airport might may be a helicopter version of an impossible turn.
I’m curious when the pilot got the fire light and initiated suppression. Maybe the FDR will provide info on the timing.
Even still, the suppression is strictly for the engine it’s self. Maybe an APU if you’re lucky (which likely doesn’t work in flight).
Fire anywhere else on a helicopter is a stop watch from flyable to catastrophic metal failure of some critical part. If we had the option of a seat, that would be the time to hit it, but since we can effectively land anywhere that’s more the option.
Only thing that scares me more than a fire is a hydraulic failure, just because there is no manual back up in anything bigger than a Huey. Once that goes you cease being a voting member of the aircraft directional control committee.
My new favorite descriptor!!a voting member of the aircraft directional control committee.
Acordimg to the Army, you dont have to be a genius to fly a helicopter.I guess the Army doesn’t fear a shortage of freshly minted Warrant Officers.
Anal airplane? No wonder they kept the F-117 dark for so long, do you own a bidet?A fire is not one to mess with though. It’s a Land Immediately EP, like I mentioned before that’s a luxury fixed wing doesn’t routinely have. Although if a fire is bad enough in anal airplane, it might become a land anywhere also. Even trying to fly a few miles back to an airport, might just be too far as it comes to a fire in a helo. Use its abilities to set down nearly anywhere.
