*Legit 121 airlines. Not this d/b/a operation.
And yes, 121 is safer than 91.
Same back to you about 91 operationsYou’re delusional if you think all 121s are the same.
Question for the pros - does the wrong engine get rolled back as frequently in the sim as it does (seemingly) in real life? Was just wondering if this was a function of stress that can't really be replicated in the sim.
Pilots do dumb things. I try and learn from it, so I maybe will stop myself from doing dumb things too....
That’s a problem in the 121 world for sure.
Checklists that take too long to run, instead of prioritizing getting the aircraft on the ground. The engine failure after takeoff at spirit took about 20 minutes to run. That’s excessive.What? Running checklists?
Almost to a fault. Didn't Sully start the APU after flameout even though it was step 23 in the dual engine failure? And caught flak for it?What? Running checklists?
Lets not forget this was at night. Over water. Black hole departures are a thing and add complexity and stress to a situation that is rapidly going south.Question for the pros - does the wrong engine get rolled back as frequently in the sim as it does (seemingly) in real life? Was just wondering if this was a function of stress that can't really be replicated in the sim.
And probably written by lawyers not pilots.Checklists that take too long to run, instead of prioritizing getting the aircraft on the ground. The engine failure after takeoff at spirit took about 20 minutes to run. That’s excessive.
Hey, that’s the NearJet’s step 1 too!And probably written by lawyers not pilots.
The GIV checklists for an engine failure after V1 first step was 1. Maintain directional control.
Really?
Really?
We’ve been waiting for you to do this for a long time…
If the engine isn’t an uncontrolled fire that won’t go out, who cares?
Same back to you about 91 operations![]()
Well, in this case the engine was very not on fire, but they wound up crashing in to the ocean in the middle of the night and very nearly becoming fish-food, when they could easily have turned around and landed right now.
Landing an airplane isn't a freaking shuttle launch. Is the gear down? Are the flaps configured? Is the runway long enough? Do we have a good ref?
In general I agree with the "slow and steady" philosophy, but there are going to be some moments, however well one tries to engineer a "slow and steady" solution to every situation, which are exigent enough to require some individual initiative for an optimal outcome. IMHO, this was one of those.
