Fighter jets chase small plane in Washington area before it crashes in Virginia
The Federal Aviation Administration said a Cessna aircraft crashed into mountainous terrain in southwest Virginia.
The Federal Aviation Administration said a Cessna aircraft crashed into mountainous terrain in southwest Virginia.www.reuters.com
It might have been following a very-extended runway centerline, 240°Why would it return to point of departure, was the flight plan in the box (Or Garmin) set-up to tp 09A-ISP with 09A as the alternate?
Is the transponder connected to gen busses on the citation? Never flew one.A user on the radioreference forum reported hearing the jets say they could not see anyone in the cockpit. ABC News reports the jets saw the pilot passed-out.
N611VG Flight Tracking and History 04-Jun-2023 (0A9-KISP) - FlightAware
Track N611VG flight from William B Greene Jr Rgnl to Long Island MacArthurflightaware.com
Both the FlightAware and ADSBExchange tracks end abruptly at FL350.
Possible hijacking? Why no descent into ISP? so strange when you see past data. We’ll see what the investigators say if anything. Fox News is pissing me off. Now I know why so many on the right think the election was rigged. sensationalize much?
Yeah that’s a good theory. Like to know about that turn at 340. And sudden LOS doesn’t seem consistent with previous accidents related to loss of control due to hypoxia. There’s at least a bread crumb trail till 5000’ or so. Unless transponder and AP went out after fuel exhaustion but still doesn’t explain why -8000 fpm would’ve been the last ping. Who knows. My gut says they were shot down. But the flying the approach is a good one. That final turn however and then lights out, is suspect. Either way, investigators will investigate and cover up stories if needed will be told. RIP to those affected today and condolences to the families going through this tragic time.Flight plan and expected approach programmed, aircraft flew the approach but in the flight levels then just kept going straight
Since you're probably the most informed member from that side of the microphone, any idea as to if or when the NORDO began before approaching ISP ?
| Date: | 04-JUN-2023 |
| Time: | c. 15:25 |
| Type: |
Cessna 560 Citation V |
| Owner/operator: | Encore Motors of Melbourne Inc |
| Registration: | N611VG |
| MSN: | 560-0091 |
| Fatalities: | Fatalities: 4 / Occupants: 4 |
| Other fatalities: | 0 |
| Aircraft damage: | Written off (damaged beyond repair) |
| Phase: | En route |
| Nature: | Executive |
| Departure airport: | Elizabethton Municipal Airport, TN (0A9) |
| Destination airport: | Islip-Long Island MacArthur Airport, NY (ISP/KISP) |
| Confidence Rating: |
If it was hypoxia, I can't work out how it turned around and flew back to VA. Although maybe, as someone mentioned above, it intercepted the final approach course from the FMS and then just kept on truckin?I actually called out sick today to go riding lol. But it was way up in Centers airspace, mine ends at 10k. But ife heard that center was trying to reach them on guard well before they got to ISP.
560 appears to be capable of single pilot, but also not in the ‘know’ on those.If it was hypoxia, I can't work out how it turned around and flew back to VA. Although maybe, as someone mentioned above, it intercepted the final approach course from the FMS and then just kept on truckin?
I can't keep the Citations straight, but that's a crew aircraft, yes? Like it's not just one well-heeled used car salesman behind the wheel?
I certainly don't think so. Why the tight spiral at the end? Unless they shot it down I guess. The autopilot would have had it trimmed out pretty good. That airplane went from straight and level at 34000 @19:22:14z to a rapidly accelerating right hand spiral at 28,000fpm down to a smoking hole at 19:23:35z. A minute and 20 seconds later. That's not a normal flameout driftdown.Payne Stewart 2.0? Bummer, RIP.
Not sure, but why shoot it down at that point? Well past D.C. and no immediately apparent harm.I certainly don't think so. Why the tight spiral at the end? Unless they shot it down I guess. The autopilot would have had it trimmed out pretty good. That airplane went from straight and level at 34000 @19:22:14z to a rapidly accelerating right hand spiral at 28,000fpm down to a smoking hole at 19:23:35z. A minute and 20 seconds later. That's not a normal flameout driftdown.
So what caused him to finally fall foward after all that time of unconsciousness?Rapid spiral descent could also be caused by a heavy unconscious person falling forward into the control column, following a random bump or whatever. I mean, I doubt they would have been wearing their shoulder straps at altitude?
Of course a good shoot down conspiracy is more interesting and believable for the vast majority of people
