CargoLux 747 loses Main Gear
As far as I understand it, they said they had some unspecified problem, dumped for ten minutes, and returned. I'd be curious to hear what the problem was, as, judging by the speed, I suspect they dumped to max landing weight and went right in.
It seems like I read it was a failure of some/all gear to fully retract.
Could be a coincidence but the center trucks are the ones with the body gear steering. The last picture in the OP of the gear on the ground almost looks photo shopped. There’s no oleo/main gear strut/torque links/etc. Did those parts really shear off (or fall off) that cleanly? It’s supposed to look like this:
View: https://flic.kr/p/7AeF
Different 747 for reference:
Dayum! Broke the torque link below the body gear steering actuators and there’s a little bit of unbroken oleo left. Oleo looked to me like it may have been intact in the video and then got broken during the tumbling down the runway. Looks like the entire oleo strut shot out the bottom of the main gear outer cylinder with the wheels and bogie attached.
Aircraft is LX-OCV, has always been with Cargolux, and is 23.9 years old.
My understanding is 744 structural D-checks occur on an 8/8/6 schedule (8 years, 16 years, 22 years?). I have no specific information about the maintenance history of this specific aircraft.
There is a sequence valve (shuttle valve) that positions the gear for retraction position and extension position (I forget the terminology). The valve, actuator, or linkage probably failed preventing proper retraction.
Upon landing it would cause a position where the truck angle would not be dampened upon touchdown and cause an oscillation or bounce possibly overstressing and causing separation.
Just a guess. Could have been socialism....
