Roger Roger
I am le tired
When i go to recurrent I’ll have to play around with some engine failures with inop rudder boost just to see what it’s like.
Do you ever do simulated failures at V1?I'm a training captain for 500-series Citations at an operator who does lots of training and checking in the actual airplane. I've done quite a few simulated engine failures on climbout by pulling a throttle to idle immediately after gear retraction. So at about Vr+20 or Vr+30 probably.
The actual airplane is considerably easier to fly than in the sim. The sim requires mashing the rudder to the floor and holding it there. The actual airplane requires very little rudder pressure compared to pretty much any piston twin or small turboprop like a King Air. I couldn't tell you specifically how many pounds of pressure it needs, but I brief new pilots that it will probably be easier than whatever twin they've previously flown, and after doing it, nobody has disagreed.
Honestly this is the way it should be.
Top quality training, airline procedures from day one, heavy use of sims, and high standards. It must cost a fortune, which is why US based airlines will never go for it.
$180K for two years? Two years? ATC sounded like European expats.
I know they are getting PAID!!!!!!!
No. There's no specific guidance prohibiting it as far as I know, but I don't personally feel like the risk is worth the reward. Kind of like practicing a high speed abort or something.Do you ever do simulated failures at V1?
Yea I would say that 20-30kts is quite significant and really shouldn't be used to draw a comparison. Also the performance setup for the sim profile is fined tuned to be challenging yet successful with proper technique.
I'm curious have you tried the same technique in the simulator and how did it behave?
777 has something similar from what I've heard.
@typhoonpilot would probably be the best to ask since Jimmyflyfast doesn't come around these parts anymore. Not sure we have any other 777 guys on here.
Basically at the supposed speed this flight was at on the ground would a 777 start flying?What was the question?
(Without anyone doing anything rash, like pulling back on the yoke. At all.)Basically at the supposed speed this flight was at on the ground would a 777 start flying?
I was curious if, when trimmed and configured properly for takeoff, a 777 would be generating enough lift at Vr+50-70 knots to get airborne without any control input from the crew.What was the question?
Thank you, that all makes a lot of sense.To be perfectly honest that is not something I have ever tried in a simulator. I would say, at some point, yes it probably would but I ever never tried to find that point.
I really think that the data that is being reported is wrong. Normal rotation speed at their approximate takeoff weight would be 175 KIAS. That is the point the PM says "rotate". A slow rotation rate could easily see the airplane still on the ground at a speed 10-15 knots beyond that. That is not unusual. Tire limit speed is 204 knots on rotation (higher than the 226 knots on landing due to the pressure a tire encounters during rotation).
So the question I have is how accurate is this reported Fight Radar 24 (or whatever) data that is showing them still "on the ground" at some high speed? They could easily have had main wheel lift-off at 190 KIAS in a normal slow rotation and then been slowly climbing as the airspeed increased to the reported value.
My sources say this was not a big deal until it was reported in the press. Yes, it was a screw up and yes they did overspeed the flaps, but it was not as sensationally low to the ground as is being reported. Think about the possible calibration error of the Flight Radar 24 plot. If it was even just 50 or 100 feet off in calibration it changes the whole story.
Could you expand on this? That seems contradictory to what I'd imagine the forces being on landing vs rotation. I'm assuming it's related to the difference between MTOW and MLW?
Yeah that's kind of what I was thinking. I don't know the technical terms but the pivot point being the MLG at rotation at MTOW certainly has to add quite a bit of stress to the tires, I just would have thought the variability of impact forces depending on descent rate at touchdown would lead the engineers to a more conservative speed to protect tire integrity on landing. The temperature differential is certainly a logical factor as well, but this is way outside my area of expertise or experience so I really appreciate your input on this topic.Good question. The first time I saw the difference I did a double take as well. Thinking about it further though, especially for large airplanes, the stress on the tire during the takeoff roll is going to be higher because 1) the airplane weighs more; 2) during initial rotation the pivot point is about the main wheels so they are getting compressed until they become airborne; and 3) the tire tends to be at a higher temperature during takeoff due to the heat build up during taxi. That heat build up can lead to tire failure in extreme circumstances (see Continental 603).
Some good articles on aircraft tires:
AERO - Exceeding Tire Speed Rating During Takeoff (boeing.com)
AC 20-97B CHG 1 (faa.gov)
Thanks for so clearly explaining that.Good question. The first time I saw the difference I did a double take as well. Thinking about it further though, especially for large airplanes, the stress on the tire during the takeoff roll is going to be higher because 1) the airplane weighs more; 2) during initial rotation the pivot point is about the main wheels so they are getting compressed until they become airborne; and 3) the tire tends to be at a higher temperature during takeoff due to the heat build up during taxi. That heat build up can lead to tire failure in extreme circumstances (see Continental 603).
Edit to add- I imagine the fact the landing gear struts are already pretty compressed on rotation as opposed to being fully extended on landing must play a factor in loading force as well. I also suppose the risk analysis of blowing a tire on touchdown vs rotation would bias a restriction towards protecting the landing gear on takeoff. Great thought exercise, thank you
