msmspilot
The P/CG states, as the definition of circling approach: “See CIRCLE-TO-LAND MANEUVER” FWIW.If you're talking about EWR ILS22 circle to 29, it's a circle-to-land maneuver, not a circling approach.
I did the exact same thing, and I wish I hadn’t also.
This one also hits very close to home and I’ve personally observed the accident aircraft over the last few days and chuckled at their similar circling antics (safely in VMC). These guys were clearly very capable pilots and loved short approaches, but tonight was not a good night for it. The flightaware track gets as low as 750 ft MSL towards a 1000 ft mountain just east of the field, and field elevation is 388 ft.
Category C minimums on the RNAV (GPS) Rwy 17 are 1360-3, and they cancelled IFR to use runway 27R instead. Runway length available was Rwy 17 4145x100 vs. Rwy 27R 5342x100. Any Lear 35 drivers know if Rwy 17 would have been an option with wind variable at 5 kts?
KSEE 280255Z VRB05KT 3SM BR BKN020 OVC026 10/08 A2998
Edit: NEST doorbell cam footage.
Yes. They are as one of our pilots calls it “the medevac road show”. In other words instead of working with one health care system out of a base they go on the road for 7-10 days at a time and charter to whoever can provide them with a med crew and a patient.That plane certainly has a lot of travel history all over the country. Is that common for a medevac Lear type of operation?
Shaker and pusherWhat kind of stall protection does a Lear 35 have? Shaker? Pusher?
I'd love to see that text as I'm genuinely curious on the delineation.My FOM says there is.
Huh. I saw this ship come through Hillsboro when I was there a couple weeks ago.
The accident aircraft. They swapped with another one of their company that was broken.
I’m never to old to learn…My FOM says there is.
Very common. In 2015 I flew 1160hrs & 2016 I flew 990hrs.That plane certainly has a lot of travel history all over the country. Is that common for a medevac Lear type of operation?
I talked to the CP about a part time job there about 10 days ago. Wasn't part time enough for me, though. Seemed like a good guy. Sad situation with this crash. They canceled to get out of the "no circling at night" note on the chart and it went downhill from there. They must have felt they knew the local terrain well enough to pull it off. 9L would have been a better option than 17 but there was probably a pretty good west wind at altitude even though surface winds were variable at 6. 17 just seems kinda short for a Lear (like I'd really know) and if they felt 9L wasn't going to work with a potential tailwind, then better off going somewhere else. Easy to speculate the next morning having my coffee sitting on the couch. Wonder what their duty day was like. Fatigue and the desire to go home can make you do stupid things sometimes. That's why minimums, company procedures, and a strong safety culture are important. For example, if it was a 121 operation, you might have a dispatcher decide this airport isn't going to work for this flight under these conditions.
Minor point, but 130 is closer to normal ref flaps full. Circling ref with flaps 14 is probably closer to 150? Idk I have exactly one flight in the airplane and a half ass company ground schoolFrom another Facebook group, but here’s the “Circling NA” note you speak of:
I just wanted to share for emphasis because FAA / Flightcheck / etc was smart enough to say “Gee maybe we shouldn’t let people turn at low altitude in inclement weather towards the 1000 ft mountain that’s half a mile from the end of the runway.”
I also want to re-emphasize that I don’t think what they did was a by the book circling approach, because 750 ft MSL there is 362 ft AGL at 130 knots, and they cancelled IFR to do it. I would call that a “carrier break” at that point, and even those are flown at 600 ft AGL over water. I’ve seen the exact accident aircraft from the ground doing interesting “aggressive” looking circling over the last few days and laughed about it (it genuinely looked like fun in VMC at pattern altitude), so I share your concern that fatigue/spatial disorientation helped inadvertently take their regular procedure down closer to the deck.
I’ve done a decent bit of flying at Gillespie and it’s my new home airport. I genuinely really enjoy it, the tower is awesome to work with, the runway configuration is interesting and the 1000 ft mountain (Rattlesnake Mountain) you either have to turn base behind or in front of for a very very short approach is a hoot. But I don’t think local San Diego pilots give Gillespie enough credit for how dangerous it is, as it is literally situated in a bowl surrounded on all sides by rising terrain and in a heavily populated area.
I completely agree that the tailwind for runway 9L was probably too high, and suspected that 17/35 was a little short for a Lear. I certainly get the “get-there-itis” argument where the company is probably pressuring you to put the jet back in their own hangar for the night, but good grief you’ve got Montgomery and the ILS 28R 5 minutes away. SAN, SDM, RNM or CRQ are all reasonable alternatives as well and we are lucky there’s no shortage of IFR airports in this little area.
Been a long time since I’ve flown a Lear and not for very long at that, but pulled out the tab data and depending on weight with a wet runway factor it could require as much as 4000 feet. As much as 2900 dry.I think 4100’ would be fine, a little on the short side.
