ppragman
No pasa nada.
You’re actually the first person to guess correctly. Congratulations!
I was leaning towards badger gangbang but I didn’t want to sound silly if I was wrong, possum orgy seemed more French.
This has been addressed before but what is that weird noise that sounds like a possum orgy immediately before pushback in the cabin?
Seriously though, is it just running a self test or, what’s it doing? Because I’ve ridden in a lot of A3xx airplanes over the years, and I can’t recall hearing that noise in cruise.Hydraulic PTU.
And it's a robotic dog that is used for fire detection.
It only runs when the pressure difference between the Green HYD and Yellow HYD is >500 PSI. One system pressurizes the other. If you’re hearing it in cruise someone is having a crappy day.Seriously though, is it just running a self test or, what’s it doing? Because I’ve ridden in a lot of A3xx airplanes over the years, and I can’t recall hearing that noise in cruise.
but that might just be the ambient noise overpowering it.
Thanks! Appreciate that!It only runs when the pressure difference between the Green HYD and Yellow HYD is >500 PSI. One system pressurizes the other. If you’re hearing it in cruise someone is having a crappy day.
It runs a self test during the second engine start, or if someone is taxiing around and forgot to turn on the yellow electric pump. Also usually at the gate after shutdown when the hydraulic pressure is dropping.
Essentially “how do we make this feel normal because we have a stupid FBW system that feels like absolutely nothing so otherwise it would be unflyable.” Starts pitching down around 30ft to basically “trick” you into pulling up and flaring.So what is Flare Mode, and why does it exist vs just whatever Normal is?
Can you tell I’m still not a fan of the bus?
That’s probably personal preference. It pretty much feels the same always, I’d say fairly tight and snappy, but since the roll control commands a roll rate, IMO gusty crosswind landings feel kind of odd. To me it feels ok when it’s smooth, but gives me weird “Dave & Buster’s arcade game” vibes. Not a huge fan of how it feels when it’s anything other than smooth, but I also complain a lot. I definitely prefer something with a little more feedback.That is actually pretty interesting… is there no feedback to the side stick at all? Also… how “tight” are the controls? Do they feel sluggish evenly throughout the flight, or are they snappy?
Something I’ve always wondered.
It's sensitively numb, and there's no trim, which is weird.
If you hold it forward (in normal law) you’re commanding less than 1G, so it’ll keep pitching over until you run into the pitch limit, and then you’ll get “I’m sorry, Dave, I’m afraid I can’t let you do that.”That’s remarkably strange. Like, if you hold the stick forward does it trim until when you let off that pitch angle is neutral?
Do all the variants fly the same because they’ve been programmed to fly that way?
From a user interface standpoint - do you like how it doesn’t have conventional trim and pressure? As an operator what (in the controls) do you wish was different?
Thanks for humoring my curiosity- literally the most advanced flight controls I ever actuated were hydraulic flaps and electric trim, so I’m kind of out of my element on this topic.
Can you tell me why the 737 sucks so bad?
Money, capitalism, Southwest, American, and political corruption.Can you tell me why the 737 sucks so bad?
The only thing I would really change is tying the side sticks together such that moving one moved the other. That way, you know what the other pilot is asking of the airplane.From a user interface standpoint - do you like how it doesn’t have conventional trim and pressure? As an operator what (in the controls) do you wish was different?
Properly speaking, it’s still pitch normal until after weight on wheels, and the transition back to ground mode; the nose down trim increment provides a conventional flare feel but does not alter the basic function of the load factor demand.You have to hold a lot of stick back pressure to get the airplane climbing because you’re fighting that nose down trim while in direct law until it blends into normal law on climb out and auto trims it. It’s all weird. I probably didn’t explain some of it right, but it’s a unique airplane.
The E-jet doesn’t provide any protections beyond angle of attack limiting, and even then a conventional stall warning with a conventional recovery was provided. I’m in no way trashing the way that airplane flew—it is also a very nice aviation appliance—but the Airbus approach is fundamentally different and much more aimed at protecting you from yourself and, by extension, the people in back. Granted, Airbus have walked back off the idiotproof nature of the airplane, as the universe tends to laugh and build better idiots.If you hold it forward (in normal law) you’re commanding less than 1G, so it’ll keep pitching over until you run into the pitch limit, and then you’ll get “I’m sorry, Dave, I’m afraid I can’t let you do that.”
To really dumb it down in most situations in any phase if you put the airplane in an attitude and let go of the stick, it’s going to stay exactly where you put it. Which of course in the real world never happens because of wind, bumps, etc. I’ll give my own answer and I’m curious to hear his and other Airbus pilots answers, but I don’t particularly care for it, I kind of miss the more conventional feel of… every other airplane I’ve flown. Not to be to “well, on the Embraer…” but the 175 while being FBW still very much to me felt more like an actual airplane in control inputs and still had actual trim. It’s fairly complex, but the theory is fairly easy to get once you understand it, and there’s a reason it’s usually covered fairly in depth in initial training and recurrent. But “getting it” and liking the actual feel of it are two different things.
