Ag plane with folding wings
I imagine cycles with regard to crop dusters should be measured in some other metric other than take offs/landings.
I’ll preface this with I don’t know that much about fatigue analysis, but you’re right that’s an oversimplification of a cycle. There are lots of types of cycles, including aerodynamic loads, gust loads from turbulence, landing loads, ground handling loads, vibrations (like what limits helicopter blades to a certain number of hours before they get thrown in the trash) or even sonic fatigue due to noise.
They’re split up into high cycle or low cycle like this:
You can make a fatigue spectrum by superimposing the high cycle stuff on the low cycle stuff as shown to try and approximate the different types of cycles an airplane will see each flight.
There’s a specific fatigue spectrum picture I remember from school called the Ground Air Ground (GAG) cycle, and that’s what I was referring to before with takeoffs and landings, but really it should include the low cycle and high cycle fatigue stuff superimposed and try and predict a whole flight:
(Source, looks like a good read:https://smartutsa.files.wordpress.com/2014/07/load-and-stress-spectrum-generation_ld.pdf)
Unlike steel there’s no fatigue limit for aluminum and as you continue to add cycles it just keeps degrading until it forms a fatigue crack. Extensive materials testing has been done on every type of aluminum to generate S-n curves (stress vs. number of cycles) and you can see the difference between steel and aluminum in this one - as cycles (n) increase the allowable stress (S) continues to go down, where as it bottoms out for steel and theoretically continues to infinity.
I want to read up more on the C-130 accident you talked about due to the 3 bladed props being out of sync, but I think that’s an example of unplanned for high cycle fatigue (due to vibration from the out of sync props?) eating away at the number of cycles the engineers had anticipated and prematurely weakening the metal in the wing carrythrough box until it cracked.
As for the ag plane example, I would think types of cycles would include takeoffs, landings, each drop itself and yanking and banking around at low level (all low cycle fatigue events) along with the high cycle events like gusts etc. Fortunately ag planes are built like brick •-houses so I imagine this stuff takes a long time to manifest, but with enough maintenance neglect (specifically inspecting for cracks and arresting crack growth with repairs) and the perfect storm of fatigue and corrosion that is ag flying I guess it can inevitably happen like what happened in Brazil.
  • Like
Reactions: bp
The chemical mist they fly through is hard on the airframe. I had the “pleasure” of ferrying a Pawnee 30 miles to a shop after the season was over. I had to change my clothes to get rid of the smell.
The Pawnees my glider club uses as tugs haven't dropped in 25+ years, they still smell like malathion.
The accident aircraft had four-bladed props but was originally equipped with three-bladed props that were replaced for a number of reasons including role in damaging vibration.
[/QUOTE]
Weakened spar. These photos were shared on the Facebook group with the original video.
To my slightly trained eye, it looks like a fatigue failure of the built up aluminum extrusions surrounding the wing attach bolt. The “tree rings” are a sign of relative displacement of the metal. The fatigue crack probably originated at the edge of that bolt hole (where the stress concentration factor is the highest) and worked it’s way through the metal over many years. There’s also corrosion on the bolt and in the hole which certainly wasn’t helping matters.
This is a somewhat similar failure mode to the Embry-Riddle Piper Arrow, though different spar design. The AD resulting from that accident forces the removal of the wing attach bolts and inspecting the spar cap bolt holes with an eddy-current machine. Eddy current likely would have found this crack as well.
Aluminum has a finite life. Every flight is a cycle. You only get so many cycles / hours before you have to replace parts and start over.
If that bolt was removed for Eddy Current inspection of the hole, the corroded shank would’ve been a red flag that the hole would require some prep work. For example, wing folding was problematic on T-34s until an inspection and AMOC was developed. Reaming the hole up to a specified maximum diameter was permitted near the trunnion on those T-34s, but I don’t think the wing attach (bathtub) fitting had any relief allowed.
