In that case, yeah go for it. Good luck and hopefully you will like the work, I would rather work ATC then regional. If one day you decide that ATC is not for you, try getting a job as a dispatcher with a major before leaving ATC.
If you pass the academy and OJT, I would only go to dispatch if I could get a job with a major directly, would definitely not go to a regional. If being a controller in front of a radar screen is not for you, stick with it for a few years and then transition to one of the other jobs with the feds withing the ATC.
