Flashlights
  • Thread starter Thread starter bp
  • Start date Start date
I use some cheap chinese flashlight from tmart.com that uses a 18650 rechargeable battery. I also carry a personal fan that uses the same battery and recharges with a cellphone charger, so if needed I'll swap the batteries.
I used to use a Surefire and later a Streamlight but I got sick of replacing the expensive CR123A batteries.
I use CR123a 1200 mah 3.0v http://akumulatorki.cr123.pl/akumul...v-1200-mah-nowa-rcr-16340-li-ion-lithium.html and I very happy
I’ve got a Bostac BTZ-20 that is super bright. It’s rechargeable using a micro USB and I love it, except it’s a piece of junk. I have already replaced the battery once under warranty. Now I have a brand new battery and it will still just decide to stop working with no warning (indicator light is supposed to flash red when it gets low) and only lasts 3 or 4 walkarounds before needing to be charged again.... sooo I’m ready to invest in another one if anyone has a flashlight that they love.
Outdoor Tech Buckshot Pro. Not only can you use it to brightly illuminate the airplane, you can use it to pump your hot jams(tm) at 0430 in the shower.
I just carry a 7-D cell Rayovac to make sure I meet the FARs. Plus the beam is pretty good for lighting up the tail on the CRJ and satellites passing overhead.
3 pack of Outright A100 is available on Amazon for $14
That excludes the 18650 battery and charger, but for the price those are great flashlights to have around the house
Hell of a lot cheaper than a surefire and just as good. (~$50 on Amazon)
Everyone focuses on Lumens, and it’s not where you should be looking. It’s the lens. Light can be bright AF but if it doesn’t focus, it won’t light up the tail of anything.
