I'm sure they walked away whistling too...How? Why?
This rivet puller had to be disassembled because it was found jammed like this. I don't know who happened to this, but WTF?
A fairly inexperienced mechanic that might carry an opinion of their abilities that doesn't match reality can get expensive pretty quick. I once watched, from a distance, a mechanic that wanted to learn more about avionics volunteer to perform 91.411/91.413 checks on a Falcon, somehow he was teamed up with another recent A/P graduate because the avionics tech was busy. I can appreciate the ambition, but having a sense of your limitations is important. I also don't know who they thought was going to sign it off. Regardless, the plane left two days late with two replacement air data computers. Ultimately I guess the responsibilty belongs to the supervisor that allowed it to happen at all.I'm guessing that it was probably one if our general mechanics who had no idea how to put in blind rivets, but decided it can't be that hard to do. smh
Seeing that makes my brain hurt ...How? Why?
?Avionics.
A sparky thought he’d try using a cherrymax.
That's plausible. Unfortunately it brings us full circle back to the title of the thread. How? Why?A sparky thought he’d try using a cherrymax.
Wow! That's crazy!A fairly inexperienced mechanic that might carry an opinion of their abilities that doesn't match reality can get expensive pretty quick. I once watched, from a distance, a mechanic that wanted to learn more about avionics volunteer to perform 91.411/91.413 checks on a Falcon, somehow he was teamed up with another recent A/P graduate because the avionics tech was busy. I can appreciate the ambition, but having a sense of your limitations is important. I also don't know who they thought was going to sign it off. Regardless, the plane left two days late with two replacement air data computers. Ultimately I guess the responsibilty belongs to the supervisor that allowed it to happen at all.
I'm going to assume you've chosen structures as a specialty, if you're good at it stay with it (I'd also suggest getting as much composite training as possible). In my world, regarding skilled techs, there are a few disciplines: Avionics, Sheet Metal/Structures, Engines, Interior, Cabin Systems, General Tech. That seems to be the menu, I never chose General Tech, Jack of All Trades-Master of None, but that's what I do. All of these people either love or hate each other depending on the project at hand.Possibly avionics, but I strongly suspect one of the 15Ts (Blackhawk mechanics) because several of them went down to Bakers School of Aeronautics and got their A&P in two-three weeks. Came back thinking they know everything and can do my job too, even though they've never bucked a solid or pulled a blind in their life. The wire biters tend to keep to themselves and not get involved in anything outside of their wheelhouse.
I'm not mad, but when I go back to work Tuesday, I'm going to tell them all not to touch our tools, and offer training to whoever is interested. I will GLADLY show them how to do airframe stuff, all they have to do is ask.
Huh, the only rivalry I really knew of was tin-benders vs. spark-chasers.I'm going to assume you've chosen structures as a specialty, if you're good at it stay with it (I'd also suggest getting as much composite training as possible). In my world, regarding skilled techs, there are a few disciplines: Avionics, Sheet Metal/Structures, Engines, Interior, Cabin Systems, General Tech. That seems to be the menu, I never chose General Tech, Jack of All Trades-Master of None, but that's what I do. All of these people either love or hate each other depending on the project at hand.
We're both on the same "team" here - "Backshops". Engines and Powertrain are also on the "backshops" team.Huh, the only rivalry I really knew of was tin-benders vs. spark-chasers.
That makes sense, the avionics guys will require some sheet metal work for any installation that requires cutting metal for any reason and they are normally not going to try it themselves, which I applaud. Then their schedule is predicated on the sheet metal people, who may have other things they're dealing with. 99% of the time there's a deadline and no one wants to get blamed if it isn't met, that's where all of the angst comes from. The worst spot to be, in my world, might be the interior guys. All of the hard technical stuff is done right? It's just leather, carpet and wood, the things the customer is likely to see, feel, touch and smell. Unsung heroes.Huh, the only rivalry I really knew of was tin-benders vs. spark-chasers.
