I know you’re up against opsec, but I’m not so this is me regurgitating what I’ve read from open source resources over the years. All of the stuff other than the specifics is open source and in academia anyway.
I doubt the Y code (which is just the P code plus another super secret squirrel code called the W code IMS) protects you much from jamming if it’s crazy loud. If you jam the hell out of that freq such that the unit can’t hear the Y code to decrypt you’re not gonna get a signal.
The Y code will (ideally if the bad guys don’t know how the code is generated) prevent you from being spoofed though, so that’s cool, but straight up jamming is still a risk. I’m still curious about how Iran snagged that RQ-170 though. I suspect they were able to exploit some hardware or software issue but I’ll probably never get to know.
There are probably ways to use the Y code to get a position through all but the noisiest jamming, since ostensibly no one knows how the W code is generated, but I’m not sure. I think Null-Steering Antennas can help with jamming too - but I don’t know enough about the physics to intuitively know why. That said, ITAR restricts null-steering antennas along with GPS that works faster than 1,000kts or ones that can decrypt Y codes so I would suspect this is the case. Wild speculation follows.
Speaking of Y codes, if you wanted to degrade the signal for everyone else but still be able to use GPS in a location, I’d jam on the frequency of the P code with a public key then transmit a private key as a Y code. It would take the GPS a little while to boot up if it was a good encryption, but it’d be super secure and you could degrade the effectiveness of every hiking GPS being used by the Aloha Snackbar guys in an area (or just straight up deny the frequency to them). If you then went on to constantly change Y codes in some randomish fashion it’d be practically impossible to use our own GPS against us.
This is exactly how I suspect that this works (but this is wild speculation on my part) when they are doing GPS jamming practice in a region. Whatever code box or software in the GPS has a spot where you can put the Y code for the exercise into the unit. The people in the exercise then put this special code into the unit (or even better would be a series of codes over the duration of the exercise) and they practice hunting the jamming antenna while another group of people practice operating while being jammed.
