"Climb via" vs "descend via" technique in CRJ
STS-41B
Maybe it's unique to my company, maybe not. But why when we're departing and given a "Climb via" do we set the top altitude, and monitor any other restrictions on the way up, but when given a "descend via" we don't set the bottom altitude; instead most captains I fly with insist on setting the next crossing restriction, and do it step by step all the way down.
There are some who adjust the VNAV angle and set the bottom altitude and follow the snowflake down, but that's very rare. I prefer that method but most captains will flip out if I do it..
I know at the majors they set the bottom but they have more sophisticated VNAV guidance probably....
What Jordan said. And some companies set the first hard altitude, and each subsequent hard altitude without setting the above, below or between altitudes.
Why do your captains flip the f out, if you have a different (but safe) method other than theirs?
You just answered your own question. Without auto throttles, the CRJ does not have a true VNAV system.
Explain this answer to me. I fly corporate jets without autothrottles with the proline 4 avionics and our VNAV will meet every crossing restriction. You just have to control the airspeed via throttles.
Annnd, with a full, true VNAV system, I sit there and drink coffee while the ATs control airspeed. Figured it’d be obvious enough.
I figured it was obvious VNAV stood for vertical navigation. Not vertical and speed navigation. Not being a dick but I think it’s misleading to tell someone they don’t have a full VNAV because they don’t have auto throttles. The VNAV functions as it should. I think a better statement would have been “ and with auto throttles you don’t even have to monitor speed restrictions.”
Good for you!
Sent from my Moto Z (2) using Tapatalk
Except you do, because most arrivals it's "is it gonna bug the speed reduction? Oh look, it skipped the 230 and is trying to cross it at 210."
Or if you're not paying attention and you have 1.5 miles for a 30 knot speed reduction... hello full boards.
Gee, some of y’all get triggered so easily. Like I said, I’ve flown that POS. 3000 hours worth. And now I enjoy drinking beer outta its new recycled self.
Well most of the climb vias are “at or above” so the top altitude works. Yea there are some with a couple “at or below” restrictions, and for me in the CRJ, id put that first hard altitude. All it takes is a small distraction and ya blown through it. Seen it happen many times....same with the descend via. Just easier to put a lil protection in there for yourself.
Except the CRJ doesn’t have VNAV of any type. There is no VNAV button on the MCP. You can get a vertical speed required for the next crossing altitude from the FMS but you have to manually change the vertical speed on the MCP. The CRJ has a very old version of the proline system. So it’s not just the absence of auto throttles.
Several XJ planes have a VNAV button on the FCP. It’s an option. I think most operators do not pay for it though. Without autothrottles it’s pretty useless though.
Ah didn’t know that. None of the CRJs I ever flew had that option.
Why would it be useless?
