A couple more knots, and they would have had a rinse.
http://www.cnn.com/videos/world/2018/01/14/turkey-plane-skids-off-runway-newday.cnn
Plane skids off runway, gets stuck on cliff
New Day
No one was injured and all passengers were evacuated when a commercial airliner skidded off the runway at Trabzon Airport in Turkey
I'm not sure that this an overrun, seems more like a loss of directional control during landing. There was still runway, not much, beyond the point that it looks like they took a hard left. Curious how this transpired.
Yes. They'd have been better off overrunning the runway because there's still flat, solid land that way.
On pprune the rumor is that it was dispatched with one reverser MEL'd. One guess which one.
One would assume the right. Why someone would not MEL both on a 737 if one was inop is beyond me. Reverse thrust is not a consideration when the landing distances in the AFM are certified. Wing mounted engines are obviously going to cause a huge amount of asymmetric drag with one T/R deployed. I won't speculate any further.
Just a side note. On some airplanes that require a FCU adjustment for max reverse you can just pull the CB for the T/R and when you pull up on the handle the buckets don't deploy but the engine will spool up.
Maybe they knew they were gonna overrun based on their speed and lost control? Just a guess but I guess it'll be in the report.
Without a lever lockout that seems like very bad design.
On the narrowbody airbus the differential isn't that noticeable. But I think the computer limits N1/EPR on the good engine in that case.
How would you suggest MX have a method to adjust your max reverse? Should we try to accomplish this feat standing on a ladder with the buckets deployed and the cowls open? If the CB has opened you won't have an armed indication for that T/R, checklists are important.
Edit: None of the above applies to FADEC engines.
