Roger Roger
Bottom of the list
Heh. The wrong-way turn on a direct to is a fun one.It's a fine panel, just takes a while to learn.
And there's stupid stuff- like in a 480 or FMS if you program an airway it populates all the waypoints in between your entry and exit. Not so with the Chelton (mine at least, maybe it's just too old). So when you get "proceed direct to SOBAD" it's time to get out the chart (thank you ForeFlight, I love you) find SOBAD, twist SOBAD into ACTV select it and hit direct to- at which point there's a 50/50 chance the gps takes the plane in the opposite direction until you hit direct to, enter, again.
Or inputing an approach. As soon as you select it, all the waypoints get populated and your flight plan is completely jacked up. So if your last flight plan fix is 30 or 40 miles from the field, you can't actually enter the approach until given a heading or direct to an approach fix because it removes the airport as a waypoint. All this means is that at the last minute you're now doing a bunch of stuff while low, fast, and by yourself (select the airport out of ACTV, select IFR approach, select the runway, select a fix or VTF, activate it).
End of days stuff? No. Really, really annoying while flying single pilot IFR around New York airspace at 250 kts? You betcha. But hey, it's a DOS based system.
The airway thing isn’t really something that came up at the old job, so I never really noticed it.
Not sure about the loading approach issue?
So some of the route management stuff can be funky, but it does some really useful things that this shiny latest greatest Honeywell Apex I’m learning still doesn’t do. The thing I miss most is the skyway boxes-this thing has synthetic vision and a flight path symbol, but without skyways it’s really only useful doing steep turns and on a straight-in IFR approach. The skyways make hand flying (or monitoring a circa 1982 autopilot) in any phase of flight a breeze. The other thing is the VFR approach button...why in TYOOL 2017 I have to do some crazy button mashing that still only draws the approach to the center of the airport instead of the threshold....
