UA is hiring [2017]
Any info on shifts, benefits, pay?
OK, I'll bite. Shift start times are typically 0700-1500-2300 or 0600-1400-2200 depending on the desk. Mostly 8 hour shifts. There are a very limited number of 10 hour shifts but typically those are worked by fairly senior dispatchers. There are also some ATC controllers and operations managers who work 12 hour shifts, but nobody starts out in those positions. Total annual hours worked is 1880. Basic 8 hour shift rotation for lineholders is 5 on-2 off-5 on-5 off. Typically plenty of OT available. Pay scale is similar to Delta's. Cost of living is fairly high, but lower than NYC/SFO/SEA/HNL...and there are some fairly affordable areas to buy a house if you're willing to commute from the suburbs. Benefits are pretty standard, I believe starting after 90 days; there is no pension for new hires, but there is a 401K match. Good luck to all those that apply!
Actually we have 0600-1400-2200 and 0700-1500-2300. Also have some 0400 starts that are 10 hour shifts. For domestic, generally about 25 flights - transcon desks are less and depending on which area of the world you are working, international can be really less
You are correct sir. Times updated in original post.
