What's the reasoning behind squawk code changes in flight? I can't find a consistent pattern of where and why it happens. Is it just so your previous one (assigned on the ground) enroute can be reassigned for another departure at your origination?
Always wondered the exact reason but I'm guessing here it has something to do with us being fed from 3 different centers. It's really annoying, since the new code just keeps flashing at us and we can't do anything with your tag (hand offs etc) until you're squawking the right code.
I'm not sure if it's more or less comforting that you don't really know either.
So if I'm arriving into EWR, and I get a squawk change from NY tracon, the ZNY computer makes that decision based on traffic in the whole center's airspace?@JetBlast is right. Each ARTCC has its own computer and beacon codes it tracks. When a new flight gets acquired by the radar and computer, the computer (ERAM) determines if the beacon code is already in use. If the aircraft's beacon code is already used, the computer will issue a new code. If an approach control is bordered by more than one ARTCC, the ARTCC that delegates that airspace to the approach control is the computer used to figure out beacon code conflicts.
It depends on which center the airspace "belongs" to. For example, one of the sectors I work serves three approach controls, BNA, HSV and CHA. HSV and BNA are all contained within ZME airspace so if you come from ZTL or ZID and your beacon code is already in use within ZME you get assigned a new code. CHA approach sits under ZME and ZTL airspace, but it's delegated to ZTLs computer so when an aircraft is handed off from ZME to CHA approach and that code is already in use anywhere within ZTL you'll get a new code.So if I'm arriving into EWR, and I get a squawk change from NY tracon, the ZNY computer makes that decision based on traffic in the whole center's airspace?
Sent from my SM-G900V using Tapatalk
Precisely. I know there is a way for pilots to tell which approach control resides in which ARTCC. How one comes up with that information escapes me.
I think it's in the Airport Facility Directory, each individual airport page identifies the controlling center. There's also a map of the centers in there somewhere iircPrecisely. I know there is a way for pilots to tell which approach control resides in which ARTCC. How one comes up with that information escapes me.
Or you could look at the center boundaries that are depicted on a high enroute IFR chart.
The thing I used today to block the sunA what?
In a jet
At a 121 operator
In 2017
High, yes. Mighty, not so much.Someone's feeling all high and mighty now that they Dash is gone![]()
