Dinner salad <70yo is a blasphemy
Tell UPS you want to be the ACP in RFD until you retire. You're golden.
General ORD area does have some outdoorsy stuff not too far away. Mostly in Wisconsin though. Door County is beautiful, and so are few other spots here and there - Devils lake comes to mind..
If you're outdoorsy / active and don't need a big city, check out Madison WI. Very active people there, and the demographics skew young thanks to the University.
If you're willing to commute by Air, Knoxville may be worth a look too. Nice and warm and right next to the Great Smokies.
If you want to stay in the northern Illinois/Wisconsin area, move to Madison.
As for 2-4 years to get to the majors, good luck. Took most guys I know around 10.
Move to Ann Arbor, get based in DTW. Right @jtrain609?
It works until it doesn't.
I've seen eight bases close over the last ten years. I'm never moving for a base.
Fortress hub or bust.
Taxes are generally higher in Dane County (ie Madison) However, if your into driving a little, the surrounding counties are very affordable (for rent etc..)
Those aren't safe either. Nobody saw delta closing DFW, or Compass closing MSP. No base is ever truly safe.
If only total time was all it took.I've heard the sweet spot is 4-6 k hrs, hopefully I can build that in under a decade. But I chose skywest because I'd rather be stuck here than any other regional.
Thanks for the all the helpful comments. Guess I got some 'splorin to do in wisconsin.
Looking for a place to hang my hat for a few years is all.
