NovemberEcho
Dergs favorite member
No. TCAS requires a transponder to function.
That's what I thought which is why I don't think the Aeromexico had anything to do with TCAS development as it wouldn't have prevented that.
Perhaps it had something to do with the mode C veil? To be honest I have no idea when it came about.
Yes I believe that to be correct.Perhaps it had something to do with the mode C veil?
Does TCAS work with non-transponder/non-mode c equipped aircraft? iirc the ATC didn't notice the Cherokee because it was a primary target only.
I'll be honest I just had to look up Mode C Veil and that is definitely not adhered to by many many GA pilots. At least here in NY.
Could be a difference of having one and not knowing whether or not it's operational.I'll be honest I just had to look up Mode C Veil and that is definitely not adhered to by many many GA pilots. At least here in NY.
The only two Class B airports in NY that I know are LGA and JFK. If you're operating within 30nm veil of these two airports, you need a transponder.
TCAS requires a transponder. In LAX, the rules back in 1986 were different and the airspace was different shape TCA. Today's Class Bravo is different and the transponder requirements in Class B and the 30 nm mode C veil. With these requirements and equipment today, the TCAS would have alerted the crew of Aeromexico 498.
I thought on the Aeromexico one the ATC only showed a primary target, no transponder at all. I could be mistaken though.
I knew the controller working Aero Mexico and worked at the facility just prior to the incident. The Cherokee was in the TCA where he shouldn't have been and only had a mode/A transponder. The controller was busy and didn't point out the target assuming it wasn't in the TCA. Just prior to the crash the controller encountered another TCA violator. As I recall, this happened so regularly that the supes didn't bother much with enforcement. Perhaps a FSDO guy in the facility would have helped? Nah, nobody's got money for that....
Mode C transponders and TCAS have made the skies much safer. There was a cargo cutout for TCAS, too, back in the day. http://aviationweek.com/awin/pilot-unions-ask-tcas-cargo-aircraft
I didn't know you lived around here. Yeah we can't be below a 1000 within a mile of the coast, and need to cross feet dry at 2000 for some dumb reason or other but then usually down to 500 or sometimes 300. Thing is, the route top is about 3500 so you can get traffic on the route at 450 knots crossing the approach corridor who isn't talking to approach. I've flown under Aceys and Blue Streaks at that exact spot a few times now, but it hasn't been a 500' pass..Initial approach altitude at ELLAS is 2100 ft. GOLLA is 8.5 miles from ELLAS and also has an altitude restriction of 2100 ft. You guys are flying VR084 at what, 500 feet? I watch you guys all the time. Where VR 084 crosses Hwy 17 right after the turn NNW from going feet dry, look to your right. The idiot jumping up and gown in the yard, waving his arms over his head is me.![]()
The Piper did come up on the ATC screens, but it was somewhat last moment, and at that point the controller was dealing with another intruder in the TCA. The Air Crash Investigations TV episode did this episode and seems to explain it fairly well.
It was that episode that made me think it was a primary target only with no transponder lol. A primary target is just a dot on our scope
I wish it was still called a TCA; very descriptive.The Piper did come up on the ATC screens, but it was somewhat last moment, and at that point the controller was dealing with another intruder in the TCA. The Air Crash Investigations TV episode did this episode and seems to explain it fairly well.
