Tyler Pinkerton
The light is connected to the hot Battery bus, so if power is off on the inside, ground crews just flip the switch on the backside of the gear leg and the light will illuminate.assumption: power on the jet
Embraer really did think of everything, didn't they?The light is connected to the hot Battery bus, so if power is off on the inside, ground crews just flip the switch on the backside of the gear leg and the light will illuminate.
Joe Patroni would've just powered it out of there, no need for a tug.
Someone at XJT once tried that.
They failed.
Then lied about having tried.
I believe their employment was terminated.
Because they tried it or because they lied?
Reasonably sure either would get you canned at most airlines. As soon as your wheels leave the pavement or you get stuck, you shut it down and wait for a tug.
Sliding off a taxiway isn't a very big deal, it happens. Trying to fix it or lying about what happened is grounds for termination because of either having terrible decision making skills or lying about your terrible decision making skills.
Unless you are in the Mothaland...Reasonably sure either would get you canned at most airlines. As soon as your wheels leave the pavement or you get stuck, you shut it down and wait for a tug.
The 707 is "built to withstand anything, except a bad pilot". Don't know if that applies to the ERJ, though.
(itself, demonstrating terrible decision skills)Reasonably sure either would get you canned at most airlines. As soon as your wheels leave the pavement or you get stuck, you shut it down and wait for a tug.
Are you checked out on Fifi yet?Not really.
I remember when JetBlue needed XJT to pick up the lift from the -180s when they first got them as they were broken.
