I think you missed the pointWas a TO alternate still needed?
Harks accidentally gotcha in the eye, huh?I'd laugh at this but my CR2 memories are making my eye twitch
Yep, I did. Mea Culpa.I think you missed the point
If you change our route more northward, away from the weather, could we drop the alternate?(From an aircraft dispatcher group on Facebook.)
Best ACARS of the day:
WE WOULD LIKE TO BE REDISPATCHED W/O T/O ALT TO GIVE US A LOWER MIN FUEL.
When I was a dispatcher I just assumed position on the screen to destination.From time to time I get that captain that wants a burn to his t/o alternate. If I knew at what point you'd be declaring an emergency and divert to your t/o alternate I'd be glad to provide you a burn.
Before people laugh at this situation. During my regional days, because of the unreliable flap system in the CRJ-200...we had to plan on getting to our T/O alt at flaps 20 to comply with an AD. If this was the destination, as if sometimes is on short hauls, your burn at Flaps 20 is obviously going to be more than normal burn at flaps 0. You had to put the difference in fuel somewhere...usually in hold. If they were tight on this...dropping the to alt could reduce the minimum to fuel. Obviously this is an extreme example and is not normal procedure on most planes...but this is a reason this could happen.
Correct me if I'm wrong, but doesn't most flight planning software calculate burn/fuel/distance/time on the release when applying a TOA? The big factor in this assuring you are within the FAR limitations for a TOA.
