You done made me look at the Op Specs on my day off (something I really try to avoid on days I work, they just muddle my opinions with facts), and I haven't had coffee yet.. so could be wrong.
The Z approach is not authorized by company policies as we do not train Circle to Land. We have the ops spec (C075) but because it says we must train for it and we don't, it is illegal.
Company policy aside, our C075 has paragraph "d" that allows us to do a circle to land "maneuver" without training. It does also list the aircraft types authorized to do non-trained maneuvers with.
Did Alaska secede or something recently and no one told us?
If your ICAO airport code don't start with a K you're not in Amurrica anymore!!!!
Regardless if the company will not allow a circle to land or circling in VMC it doesn't matter, the plane isn't allowed to shoot any approach published. So again the real question is can you Plan to dispatch without a published approach, VFR, as a 121 carrier?
You must work for a different airline than I, if our company policy or procedure prohibits something that causes a delay or cancellation, it's changed within the hour. Our FOM is written on a dry erase board.
Seriously, we used to run into this issue weekly, if not daily. Lots of airports we served would take down their approaches at night (it's truly a fly by night company) and leave you with some kind of RNAV approach or nothing at all. Since the light twins we send to these s$$%tholes aren't equipped for such fancy things, we would have to wait till the out of service period ended. Then they came up with the same procedure mentioned above with the MVA and alternate requirement. (Which every time I call to get the MVA I get multiple answers... not the clearest thing we do). Which I believe is authorized by C077 in the paragraph pertaining to airports without a CVFP. The MVA+500' (or 1000' whichever is higher) and 3 miles vis procedure we use should ensure we meet the the requirements for ceiling/vis spelled out in C077 b(4). We are required to carry an alternate in this situation, but not sure if that's just being cautious or a requirement spelled out somewhere in the FARs/Op Specs, and it's too early to dig into that.
SO, I'd say if you are unable/unwilling to do a circle to runway 16 based on the ILS to 6 and have no procedure for dispatching to a No IAP airport based on C077, then you're probably stuck.
At my airline if we no longer have a ground based IAP we require an alternate and MVA to dispatch. Although...I'm not 100% positive that would be legal on a international flight...hmmm.
Ours is legal for use anywhere we operate. The example given in the manuals is actually for a foreign airport. The trick is trying to get an MVA out of the controllers, either they don't understand what you are asking for or refuse to give it.
But since its supplemental ops,I say you call the DO and he/she and the captain can get together and operate the flight without you being involved if they really wanna move the plane, and you can just forget all this stuff
