Ground doesnt say go to Tower?
I liked it back in the day when tower changed me to departure frequency in the same transmission as giving me the takeoff clearance, so I could be up with TRACON on the takeoff roll and not have to be fiddling with frequency change just after liftoff, especially in IMC. "XXX, runway 32, winds calm, cleared for takeoff, change to departure." If I remember right, ATC/tower won't give us frequency changes until passing 2500 AGL for tactical jets.
You used to get a stern talking to for switching to tower without ground telling you to un KEMT. I wonder if it's still the same?
Unless you're using #2 for ops then switch it to 121.5.... Guess we need 3 radios.
We have a third radio, but it's normally set to VHF ACARS DATA. Maybe 4 radios?
I remember hearing that pretty often at Willie when they'd give the Harriers or T38s an unrestricted climb. The F22s out here get a Hang Ten departure every once in a while (unrestricted climb to 20,000 I think?) and they are often given the switch to departure in the same clearance. I actually got the hand off in the take off clearance once out here when we were going westbound and there was no other traffic anywhere in the State.
Especially on an unrestricted climb, when we'd be zooming up into TRACONs airspace pretty quick in -38s, and there just isn't reasonable (or safe) time to be fiddling with frequency changes, especially in the jets I flew where radio heads weren't in ergonomically or anti-spatial-disorientation friendly cockpit locations. It's convenient. And if tower needs to tell you something urgent while you're on the roll, they generally have a departure frequency override or will tell you on Guard. Same thing for approaches in IMC, we many fields offer Single Frequency Approach, negating the requirement to make a freq change from approach to tower, being cleared to land on approach freq (normally a dedicated freq, like a PAR final would have), and changing to tower freq on rollout.
But you should be monitoring ground on comm 2!
I first experienced the cleared to land from approach shooting a PAR into Yuma with a student. Kind of strange being told AFTER you land to call tower.
The old -38s (the A and B models) and the F-117, believe it or not, only had one UHF Comm radio, nothing else. Crazy, I know...especially in this day and age.... but true. Hence why in those planes, formations depended on hand signals, in order to not have to make interflight comms on ATC freq. At least the Hog had 3 radios, two of which could be used for ATC.
Yeah, its common on PAR to stay with the controller like that, where he coordinates your landing clearance for you. The best are people who, when told, "do not acknowledge further transmissions", proceed to acknowledge that instruction to the controller. :D
USN/USMC ASR/PARs are slightly different from USAF/USA ones, in that the USN/USMC controllers had a radar-downwind instruction to "perform landing check".
Yuma is a USMC tower I think so we got the perform landing check request which I had no idea how to respond to. Also, some time after we go the don't acknowledge any further transmissions request we were told the arrival end cables were raised, but I had no idea how far down the runway they were and if we could roll over them in a Seminole or not. And they wouldn't respond to me questioning them where the cables were. If I recall we ended up going around (and completely screwing up their pattern with a bunch of F18s in the overhead) to come around and land on the other runway without cables.
Yeppers, they're USMC. There where the Marines are the "major user" of the joint use field, providing all ARFF, ATC, etc. As opposed to joint use fields where ANG units are minor users such as PHX.
If I'm not mistaken, the perform landing check is an advisory call only, not requiring a response. As opposed to (for military) a check wheels down call.
It's always good to double check the airport diagram to see where the cables are, and what types they are, in order to know where to expect to touch down. Upon breaking out visual, you'll be able to see the round yellow circle signs at the runway edge and yellow painted circles on the runway to see where they exactly are located too, so there's that also. But it would've been nice for the controller to at least respond to that query from you. Lol....the "do not acknowledge further" is intended for you answering him, not him answering a question from you. :D
Yuma also has....or at least had....a giant "WHEELS" bright-painted signboard located next to the approach end of the main runways. Don't know if that's still there.
It was night time and oddly the cables were not depicted on our NOS plate. Which is why the comment worried me.
That's weird. They should be there on the airport diagram on the plate, as well as the large airport diagram and marked E-28 with the bi-directional arrows.
They should still be changing tactical aircraft on the ground during the takeoff clearance. That's still in the book.
All I do is follow company policy *coughHATScough* so I'm going to just go ahead and say that if you have a beef with the way our company policy specifies radio use you can submit a suggestion. ;)
Does one email the suggestion or just call it in on guard?
Tactical jets were still switched to departure before their takeoff roll when I got out in 2014
Here it is:
FAA JO 7110.65
¶3-9-3 DEPARTURE CONTROL INSTRUCTIONS
Inform departing IFR, SVFR, VFR aircraft receiving radar service, and TRSA VFR aircraft of the following:
a. Before takeoff.​
2. Inform all departing IFR military turboprop/turbojet aircraft (except transport and cargo types) to change to departure control frequency. If the local controller has departure frequency override, transmit urgent instructions on this frequency. If the override capability does not exist, transmit urgent instructions on the emergency frequency.​
PHRASEOLOGY−
CHANGE TO DEPARTURE.
Additionally, for Air Force towers the following applies:
3. USAF. USAF control towers are authorized to inform all departing IFR military transport/cargo type aircraft operating in formation flight to change to departure control frequency before takeoff.​
I don't know. If you're approaching the runway, maybe switch over to tower or "over to tower for Airliner 123?"
I never got to land 3/21, so I wouldn't know. But that's hilarious.
