Ground doesnt say go to Tower?
Mavmb
How many times does it happen that ground control doesn't say anything to you and just expects you to dial in the proper tower frequency before takeoff? This seems to happen to me frequently.
I would say that it happens every time that I fly in and out of CLT. As well as most every other airport.
The only time I routinely notice ground verbally transition to tower is at busy Bravos.
SOP is for aircraft to switch from Ground to Tower when ready to go near the hold line. There are only two or three Class D's where that is not the case and, at those the ATIS tells you to announce ready on Ground as a "special procedure." You may get a prompt form Ground at some Class C and B facilities, but if you don't, you switch yourself unless told not to.
Typically once I get past the last taxi-way before the one leading to the runway or if intersection departure (the Twy before), then I switch over to monitor Twr & call when ready for departure & #1.
In busy Bravo morning or evenning, I wait for the hand-off to tower only if i hear them saying it to others. If not I do the above (I switch to monitor tower after passing the last Twy since ground would not be needed anymore).
" 4 − 3 − 14. Communications
a.
Pilots of departing aircraft should communicate
with the control tower on the appropriate ground
control/clearance delivery frequency prior to starting
engines to receive engine start time, taxi and/or
clearance information. Unless otherwise advised by
the tower, remain on that frequency during taxiing
and runup, then change to local control frequency
when ready to request takeoff clearance.
NOTE
Pilots are encouraged to monitor the local tower frequency
as soon as practical consistent with other ATC
requirements.
REFERENCE
AIM, Automatic Terminal Information Service (ATIS),
Paragraph 4
−1−13.
b.
The tower controller will consider that pilots of
turbine−powered aircraft are ready for takeoff when
they reach the runway or warm−up block unless
advised otherwise."
I never told the aircraft to contact tower. Seemed redundant to me. Of course the pilot is going to contact the tower when ready for departure, because the aircraft can't legally cross the hold line until the pilot does. I also didn't tell a pilot to contact ground after I was done with the aircraft on clearance delivery for much the same reason; the aircraft can't legally enter ground's movement area until contact is made and taxi clearance given.
On the other hand, I did tell an aircraft to contact ground control from the tower position, because as soon as the aircraft exits the runway he's entering ground's movement area. The exception here is if I had control of a taxiway that crosses another runway or runway approach area, in which case I instructed the pilot to remain on tower frequency.
Seems to me that's how it always happens.
KSMO (Santa Monica CA) and KCMA (Camarillo CA) have strange setups. After doing your run-up you contact ground before taxiing 40' to the hold short line. They tell you to contact tower but those are one offs.
Some airports tower tells you to switch, and some don't. Some have signs telling you to switch in-case tower doesn't.
IAH, ORD, and DEN always tell you to make the switch. SLC, SFO, and a lot of others we just make the switch on our own. LAX is nice and has a sign "Monitor tower frequency 120.95 now."
With the exception of those airports that hand you off, we'll just switch as we are close to the end.
I stopped bothering in Camarillo.
If they would just put up a sign that said "Departures - Monitor tower 128.2" that would be great.
