z987k
Well they have done it in aviation. It's all over the experimental market.This!
The fact that carburetor engines are even an option demonstrates the dinosaur thinking being caused by restriction. Seriously it's effectively wasting 20% of its energy in excess fuel being fed into the first cylinder in the firing order. There is no reason for after market bolt on EFI systems similar to what's been running in hotrods and muscle cars since the 90s shouldn't be viewed as anything but good. If Edelbrock (which is by no means a standard of excellence) can make something so simple cheaply and reliably I don't know why the same can't be done in aviation.
The "well it's the way it's always been and it's the risks we are familiar with so we are comfortable with them" is a disastrous line of thinking that infects the FAA just like any other bureaucracy. More importantly it stifles any innovation in the market because it effectively murders opportunity for advancement before its ever even worked out on a cocktail napkin or a machine shop.
A well thought out O-360 with high comp pistons(10:1), a cam to take advantage, electronic fuel injection and digital ignition makes 40hp more than the stock lycoming while burning about 6gph for the same airspeed that 55% power on the O-360 produces. Pull the timing a little and you can run 87 octane car gas. Even with ethanol if you build the fuel system with that in mind.
